IP DHCP Snooping Feature
ney25
Level 2
Level 2
Hi NetPro,
just to confirme with the DHCP configuration is that correct.
thanks.
Core-Switch
interface Vlan312
description Vlan
ip address x.x.x.x 255.255.255.0
ip helper-address x.x.x.x
no ip igmp snooping explicit-tracking
ip ospf message-digest-key 5 md5 7 xxx
no ipv6 mld snooping explicit-tracking
standby 112 ip x.x.x.x
standby 112 timers 2 4
standby 112 preempt delay minimum 15
ip dhcp snooping vlan 312
no ip dhcp snooping information option
ip dhcp snooping
Access Switch:
interface FastEthernet6/41
description user
switchport access vlan 312
switchport mode access
spanning-tree portfast
ip dhcp snooping trust
your reply will be highly appreciated.
thanks
jack
2 Accepted Solutions
Hi Jack,
In the "ip dhcp snooping" command the option vlan is actually a vlan-list.
You should select the vlans where you want to enable dhcp snooping.
Example:
ip dhcp snooping
ip dhcp snooping vlan 1,2-5,20
This will enable dhcp snooping on vlans 1, 2 to 5 and 20.
Cheers:
Istvan
Hi, apologies for not replying to your earlier message regarding option 82 insertion - I had gone to bed... However it looks like your query was answered anyway.
With DHCP snooping it is also recommended to rate limit the DHCP requests on the access ports using the command:
interface FastEthernet0/1
ip dhcp snooping limit rate 100
In the campus design presentation from Networkers 100-pps is recommended, however it may be worth tuning this down even further. On the DHCP server port or Layer-2 uplinks you can also enable rate limiting of DHCP requests however these are aggregation points so the rates will probably need to be higher.
Be aware though that if the limit is exceeded the port is err-disabled, the idea being this is a DoS attack mitigation technique. This can be automatically recovered with the global command:
errdisable recovery dhcp-rate-limit
Andy
9 Replies 9
Istvan_Rabai
Level 7
Level 7
Hi Jack,
ip dhcp snooping information option is enabled by default. Is there any reason why you disabled it?
Otherwise, your config is alright if the DHCP server is located on FastFthernet 6/41.
Cheers:
Istvan
Not all DHCP servers support Option 82 insertion and leaving it enabled prevents DHCP from working. Windows 2000 & 2003 don't support it and as most of the world uses these as DHCP servers it generally gets disabled....
Andy
Hi Andy,
thanks for your infomrations, it's really help me a lot.
which means i put no ip dhcp snooping information option is correct ?
and 1 more thing i need to confirm.
interface FastEthernet6/41 --> to DHCP server or to DHCP client
so, below 3 lines command configure at Access Switch or Core-switch ?
ip dhcp snooping
your reply will be very appreciated.
thanks a lot.
regards,
Jack
Hi Jack,
The interface where you configure "ip dhcp snooping trust" should not be a DHCP client port.
Cliient ports should remain untrusted, otherwise dhcp snooping will lose its function.
The
ip dhcp snooping
lines should be entered on all access layer switches.
interface FastEthernet6/41 is the interface where your dhcp server is located, or the path where the dhcp replies arrive back from the dhcp server located somewhere else.
Cheers:
Istvan
Hi Istvan
your reply really help me alot.
but, i am curious about the " ip dhcp snooping VLAN-ID " . this VLAN-ID means DHCP server VLAN ? coz, as you know DHCP Server pool many VLANS for Client. so, which means i dont have to pool for all individual vlans ? says VLAN 312 (Server Farm), VLAN 3(Admin Office user) , VLAN 4(Printer). so, when i put " ip dhcp snooping vlan 312 " will consist all ?
thanks man :)
your reply will be higly appreciated.
Jack
Hi Jack,
Example:
ip dhcp snooping
Cheers:
Istvan
Hi Istvan,
Thanks for your answer.
you've answered my doubt.
thanks a lot.
have a nice day :)
Jack
You're always welcome Jack!
Thank you very much for the ratings.
Istvan
Andy
