ip route add not showing up
cstpierre4
we have a cisco 3750-48 port switch.
We have a few SVI's configured and some static routes configured.
I had created a new interface vlan and gave it an IP. I can ping the gateway.
Now I want to add a static route to go out that interface.
when I add:
ip route 10.x.x.x 255.255.255.0 10.52.10.1
it eccepts it (no errors) But, it does not show in the routing table nor in the config?
Any suggestions would be helpful as to how to add the static route to go out that vlan interface.
15 Replies 15
Richard Burts
Some additional details would help us to understand the issue better and to be able to give you better suggestions.
As a start perhaps you could post the output of show ip interface vlan
Rick
Rick
Hi sure,
here it is.
switch#sho ip interface vlan153
Vlan153 is up, line protocol is up
  Internet address is 10.52.159.69/26
  Broadcast address is 255.255.255.255
  Address determined by setup command
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP CEF switching is enabled
  IP CEF switching turbo vector
  IP Null turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Probe proxy name replies are disabled
  Policy routing is disabled
  Network address translation is disabled
  BGP Policy Mapping is disabled
  Input features: MCI Check
  Output features: Input interface drop, Check hwidb
the route being added is:
ip route 10.140.110.0 255.255.255.0 10.52.159.65
I just tested on Cisco 3560 and its working fine for me.
Eg:
SW1--------------------SW2
Conf from SW2  ( Similar config exist on SW1 with just lo1 ip address 1.1.1.1 )
I will create the route on SW2.
Vlan10                 10.10.10.2      YES manual up                    up
Vlan20                 20.20.20.2      YES manual up                    up
Vlan30                 30.30.30.2      YES manual up                    up
ip classless
ip route 1.1.1.1 255.255.255.255 10.10.10.1  >>>>> Tried both ways and its showing under the config.
Switch#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
Gateway of last resort is not set
     1.0.0.0/32 is subnetted, 1 subnets
S       1.1.1.1 [1/0] via 10.10.10.1 >>>>>>>>>> Static route is showing now.
Action plan:
Whats the version you are running on your switch?
Can you try configuring on other switch and provide us the result?
Inayath.
Akash Agrawal
To see static route into routing table, you need to have
1. next-hop reachable (it is there in your case)
2. "ip routing" should be enabled on switch.
After configuring "ip routing" , please share output of "show ip route"
The original poster describes the issue as this
The next hop in the static route is  10.52.10.1
The interface address is  10.52.159.69/26
Pretty clearly the next hop does not go out that interface.
So the first problem is that the next hop is not out the interface where the original poster wants it to go. I suspect that there is another problem which is that the next hop of 10.52.10.1 may not be reachable. Perhaps the original poster can post the output of show ip route 10.52.10.1
Rick
Rick
Sorry about that. I was just using those IP's as examples..
Here is what they IPs are:
interface vlan153 and Ip address is =10.52.159.69/26
and the route being added is:
and the gateway is reachable. I can ping 10.52.159.65.
But when i add the below route. it looks like its added(no errors etc..) but it doesnt show in the config or in the route table
Thanks for the clarification. So this reflects what you sent in a previous response to my request for information about the VLAN interface. I assume that the information in that post is still accurate (most especially the IP address and mask of the interface and that the status of the interface is up/up)? Can you verify that IP routing is enabled on the switch?
Perhaps you could post the output of show ip protocol and the output of show ip route from the 3750?
Rick
Rick
Hi sure,
here it is:
switch#sho ip protocol
% Invalid input detected at '^' marker.
switch#sho ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 10.3.95.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 10.3.95.1
      10.0.0.0/8 is variably subnetted, 6 subnets, 4 masks
C        10.3.95.0/25 is directly connected, Vlan149
L        10.3.95.4/32 is directly connected, Vlan149
C        10.52.159.64/26 is directly connected, Vlan153
L        10.52.159.69/32 is directly connected, Vlan153
C        10.133.192.16/28 is directly connected, Vlan105
L        10.133.192.20/32 is directly connected, Vlan105
      213.212.68.0/32 is subnetted, 1 subnets
S        213.212.68.201 [1/0] via 10.133.192.17
      213.212.72.0/32 is subnetted, 6 subnets
S        213.212.72.130 [1/0] via 10.133.192.17
S        213.212.72.143 [1/0] via 10.133.192.17
S        213.212.72.144 [1/0] via 10.133.192.17
S        213.212.72.151 [1/0] via 10.133.192.17
S        213.212.72.153 [1/0] via 10.133.192.17
S        213.212.72.171 [1/0] via 10.133.192.17
      216.83.186.0/32 is subnetted, 6 subnets
S        216.83.186.57 [1/0] via 10.133.192.17
S        216.83.186.66 [1/0] via 10.133.192.17
S        216.83.186.79 [1/0] via 10.133.192.17
S        216.83.186.80 [1/0] via 10.133.192.17
S        216.83.186.87 [1/0] via 10.133.192.17
S        216.83.186.89 [1/0] via 10.133.192.17
      216.203.1.0/32 is subnetted, 1 subnets
S        216.203.1.107 [1/0] via 10.133.192.17
S     216.203.5.0/24 [1/0] via 10.133.192.17
Its weird.
Ravi Singh
Level 7
Level 7
Static route only available in routing table if the following condtionb meets.
I dont see ip routing enabled.
But there are static routes on the switch.
switch#sho run | i rout
system mtu routing 1500
no ip source-route
ip host-routing
no ip route-cache cef
no ip route-cache
ip route 0.0.0.0 0.0.0.0 10.3.95.1
ip route 213.212.68.201 255.255.255.255 10.133.192.17
ip route 213.212.72.130 255.255.255.255 10.133.192.17
ip route 213.212.72.143 255.255.255.255 10.133.192.17
ip route 213.212.72.144 255.255.255.255 10.133.192.17
ip route 213.212.72.151 255.255.255.255 10.133.192.17
Thanks for the additional information. I believe that fundamentally this problem reflects that fact that ip routing is not enabled. I believe that not having ip routing enabled has impact on things when you attempt to configure multiple layer 3 interfaces/multiple SVIs. And ultimately it impacts trying to add static routes with a next hop that is in a different subnet/different outbound interface than the static routes that you show which do work.
Rick
Rick
Got it.. Thanks for the response..
What impact if any would I see by enabling ip routing?
There should not be any impact enabling ip routing on the device.
You just telling the device that we are enabling this feature and you should support all the respestive stuff on what that feature does.
Inayath
*Plz  rate all usefull posts and mark as answered if it has resolved your query.
I am a bit more cautious than Inayath about the possible impact of enabling ip routing. If the network has been implemented on the basis that this is a layer 2 switch and routing is done on some layer 3 device somewhere else in the network and then we turn this switch from a purely layer 2 switch into a layer 3 switch (and if there are some number of layer 3 SVIs already configured) then it is possible that some traffic flow patterns will be changed.
To make the recent set of changes work I agree that you need to enable ip routing on the switch. And I am not sure that the impact of enabling ip routing will be large. But I am not comfortable saying that there will be no impact.
Rick
Rick
