IP SLA command not working
asmith252
Community Member
I am trying to configure IP SLA on a 2851 router (source) and a 3750 (stacked) (responder).  I have followed the setup instructions in the following documentation.
http://www.cisco.com/en/US/docs/ios-xml/ios/ipsla/configuration/15-0m/Configuring_Cisco_IOS_IP_SLAs_UDP_Jitter_Operations_for_VoIP.html
The 2851 will not take the following command to start the ip sla monitoring.
ip sla schedule 1 life forever start-time now
I've everything else I possibly can figure out.  Below is the ip sla configuration output.
ADMIN_2851_VG#sh ip sla configuration
IP SLAs Infrastructure Engine-III
Entry number: 200
Owner: it_dept
Tag: VG to CSW
Operation timeout (milliseconds): 1000
Type of operation to perform: udp-jitter
Target address/Source address: 10.3.10.1/0.0.0.0
Target port/Source port: 16384/0
Type Of Service parameter: 0xA0
Codec Type: g711alaw
Codec Number Of Packets: 1000
Codec Packet Size: 172
Codec Interval (milliseconds): 20
Advantage Factor: 0
Verify data: No
Vrf Name:
Control Packets: enabled
Schedule:
   Operation frequency (seconds): 60  (not considered if randomly scheduled)
   Next Scheduled Start Time: Pending trigger
   Group Scheduled : FALSE
   Randomly Scheduled : FALSE
   Life (seconds): 3600
   Entry Ageout (seconds): never
   Recurring (Starting Everyday): FALSE
   Status of entry (SNMP RowStatus): notInService
Threshold (milliseconds): 1000
Distribution Statistics:
   Number of statistic hours kept: 12
   Number of statistic distribution buckets kept: 1
   Statistic distribution interval (milliseconds): 20
Enhanced History:
Any help would be greatly appreciated!
skarthic
What version are you running on the router. IP SLA commands has variations with different software versions that you use
Some versions use
ip sla schedule operation-number [life {forever| seconds}] [start-time {hh:mm[:ss] [month day | day month] | pending | now | after hh:mm:ss}] [ageout seconds] [recurring]
Others use
ip sla monitor schedule operation-number
Check the link below
http://www.cisco.com/en/US/docs/ios/12_4/ip_sla/configuration/guide/hsicmp.html
