IP subneting
goutam_04
Level 4
Level 4
hi, i have a network 10.x.96.160/27 total 30 hosts are there in the network. I want 6 IPS seperately so can i vlsm to get the 6 ip seperately and rest of the IPS i want to use seperately.
Haris P
Level 7
Level 7
Dear ,
Wubnet your class as given below to make 6 IP's on each class .
10.X.96.160 /29
10.X.96.168 /29
10.X.96.176 /29
10.X.96.184 /29
Haris
I want to divide in 2 networks, one is for 6 ips so i can take 1st one .160/29 and another is for rest. so pls. can you tell me what will be network ip and subnet mask for rest of the ips.
what are you wanting?
You are not very clear in what you are wanting to do.
You want to subnet the block.
This much is understood.
You have a /27 which provides 32 addresses, 30 usable.
How many subnets do you want and how many hosts in each subnet do you want?
According to this last post you want 2 subnets, which by your statement would be a /28
16 addresses each, 14 usable.
Then you mention a /29
So, by what you need you will have more than 2 subnets. You will end up with 3, a /28 and 2 /29's
10.0.0.0/27
10.0.0.0 - .31
10.0.0.1 - .30
/28 255.255.255.240
10.0.0.0 - .15
10.0.0.1 - .14 (usable)
/29 255.255.255.248
10.0.0.16 - .23
10.0.0.17 - .22 (usable)
/29 255.255.255.248
10.0.0.24 - .31
10.0.0.25 - .30 (usable)
Is this what you are talking about?
