IP traffic does not propagate through an NX9000.
I have a 6509 attached to a pair of nx9000s via Ten Gig fiber which are in turn connected to four 3850s -- standalone, not stacked -- also by Ten Gig fiber. CDP shows that each device can see the next hop in the chain and VTP information propagates from the 6509 through the nx9000 to the 3850s. So far so good.
My problem arises because no IP traffic seems to pass through through the nx9000s. In the diagram below, Node B and Node C can talk to each other as expected if they are on the same VLAN. However, neither can talk to Node A nor can A talk to B or C. By "not talk" I mean that a sniffer on A sees no IP packets at all from B or C. Similarly, a sniffer on B or C sees nothing from A.
All of the connections between the switches are configured as trunks and appear to be working normally except for this puzzling lack of traffic. I guess there is some configuration required I just don't knew about yet but swlep me I cannot find it in the manuals.
7 Replies 7
how are the 3850s connected to the NX9K, that is, which interfaces/adapters are you using ?
Each switch has a ten Gig connections to one each of the NX-9000s
3850:
Te1/1/3    connected    trunk        full    10G SFP-10GBase-SR
Te1/1/4    connected    trunk        full    10G SFP-10GBase-SR
nx9000a
Eth1/6     co-3850d     connected trunk   full    10G     10Gbase-SR-S
nx9000b
johnd2310
Level 8
Level 8
If you look in the switches, are you seeing any mac addresses? What version of code are you running on the switches?
John
**Please rate posts you find helpful**
Could you give us a show runing configuration of N9K and 3850?
Should be attached
what is the state of vlan when you do a show vlan?
John
co-nx9000a# show mac address-table
Legend:
        * - primary entry, G - Gateway MAC, (R) - Routed MAC, O - Overlay MAC
        age - seconds since last seen,+ - primary entry using vPC Peer-Link,
        (T) - True, (F) - False, C - ControlPlane MAC
   VLAN     MAC Address      Type      age     Secure NTFY Ports
*    1     188b.9dc0.a0d8   dynamic  0         F      F    Eth1/1
*    1     5897.bd2b.7de0   dynamic  0         F      F    Eth1/1
G    -     00a3.8e6d.08e7   static   -         F      F    sup-eth1(R)
co-nx9000b# show mac address-table
Legend:
*    1     188b.9dc0.a0d8   dynamic  0         F      F    Eth1/2
*    1     5897.bd2b.7de0   dynamic  0         F      F    Eth1/2
G    -     00a3.8e6d.0987   static   -         F      F    sup-eth1(R)
show version on both 9000s says:
Software
  BIOS: version 07.56
  NXOS: version 7.0(3)I5(1)
  BIOS compile time:  06/08/2016
  NXOS image file is: bootflash:///nxos.7.0.3.I5.1.bin
  NXOS compile time:  10/29/2016 6:00:00 [10/29/2016 13:46:41]
