ip vlan overlapping
Darrinmc
Community Member
Hi all, I am attempting to connect 3 routers to a main router as part of a larger setup.
the relevant IP addressing table is :
Router1 (on F0/0/1) 192.168.3.2/26
Router2 (on F0/0/2  192.168.3.66/26
Router3 (on F0/0/3) 192.168.3.130/26
Main Router F0/0/1 - 192.168.3.1/26       F0/0/2 -192.168.3.65/26      F0/0/3 192.168.3.129/26
As they are on Layer 2 ports I have tried to assign Vlans ( R1- vlan10, R2-vlan20 & R3 vlan30) for the IP addressing but because they are all on the same subnet, I get a vlan overlapping error.  Is there another way to assign Vlan IP's that wont get this error?
Any assistance appreciated.
Darrinmc
12 Replies 12
Mark Malone
As an option you could isolate them using VRFs so there not in same routing space , may work for you as they will be in separate tables
Jon Marshall
I am not following, they are not all on the same subnet ie. the only devices on the same subnet are the two on 192.168.3.0/26.
Jon
I must be misunderstanding subnets ? I would think these are all on the same subnet ?
192.168.3.2/26
192.168.3.66/26
192.168.3.130/26
192.168.3.1/26
192.168.3.65/26
192.168.3.129/26
You said only 2 are on subnet 192.168.3.0/26 ? Which would they be?
Sorry my mistake, you have 3 different subnets -
192.168.3.0 255.255.255.192     -> which includes 192.168.3.1 and 192.168.3.2
192.168.3.64 255.255.255.192   -> which includes 192.168.3.65 and 192.168.3.66
192.168.3.128 255.255.255.192 -> which includes 192.168.3.129 and 192.168.3.130
Jon
balaji.bandi
Make sure no other VLAN interface already configured in the main router before you configure this.
post main router configuration to look.
BB
ERROR MESSAGE
HQ(config)#int vlan 20
HQ(config-if)#
%LINK-5-CHANGED: Interface Vlan20, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan20, changed state to up
HQ(config-if)#ip address 192.168.3.65 255.255.255.192
% 192.168.3.64 overlaps with Vlan10
HQ(config-if)#
hostname HQ
ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX15243FH3
spanning-tree mode pvst
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet0/0/0
switchport mode access
interface FastEthernet0/0/1
switchport access vlan 10
interface FastEthernet0/0/2
switchport access vlan 20
interface FastEthernet0/0/3
switchport access vlan 30
interface Serial0/1/0
ip address 10.20.20.1 255.255.255.252
clock rate 2000000
interface Serial0/1/1
ip address 10.10.10.2 255.255.255.252
clock rate 2000000
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 0030.f25c.4d01
ip address 192.168.3.1 255.255.255.128
interface Vlan20
mac-address 0030.f25c.4d02
no ip address
hostname R1
no ip cef
no ipv6 cef
interface Loopback1
ip address 172.16.0.1 255.255.255.0
interface Loopback2
ip address 172.16.1.1 255.255.255.0
interface Loopback3
ip address 172.16.2.1 255.255.255.0
interface Loopback4
ip address 172.16.3.1 255.255.255.0
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 0002.4a21.0d01
ip address 192.168.3.2 255.255.255.192
router ospf 10
router-id 1.1.1.1
log-adjacency-changes
network 192.168.3.0 0.0.0.63 area 10
network 172.16.0.0 0.0.0.255 area 10
network 172.16.1.0 0.0.0.255 area 10
network 172.16.2.0 0.0.0.255 area 10
network 172.16.3.0 0.0.0.255 area 10
ip classless
Thanks for taking the time to review.
ERROR MESSAGE
HQ(config-if)#
HQ(config-if)#
hostname HQ
ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
clock rate 2000000
clock rate 2000000
interface Vlan1
no ip address
shutdown
interface Vlan10
interface Vlan20
no ip address
hostname R1
no ip cef
no ipv6 cef
interface Loopback1
interface Loopback2
interface Loopback3
interface Loopback4
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan10
router ospf 10
router-id 1.1.1.1
ip classless
rasmus.elmholt
Level 11
Level 11
Hi there
Could you please make sure you type the correct netmask when you configure the ip address on the main router(255.255.255.192).
And maybe share with us the error you get when you try to configure the interfaces
This is the error message when I try to assign IP to VLAN 20, and then config for HQ and R1. both connected via F0/0/1.  The same happens when I do the same for R2 and R3,
ERROR MESSAGE
HQ(config-if)#
HQ(config-if)#
hostname HQ
ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
clock rate 2000000
clock rate 2000000
interface Vlan1
no ip address
shutdown
interface Vlan10
interface Vlan20
no ip address
hostname R1
no ip cef
no ipv6 cef
interface Loopback1
interface Loopback2
interface Loopback3
interface Loopback4
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan10
router ospf 10
router-id 1.1.1.1
ip classless
Take a look at this doc , what i was talking about ysterday
https://packetu.com/2012/07/12/vrfing-101-understing-vrf-basics/
Looking high level :
HQ(config-if)#
HQ(config-if)#
You VLAN 10 have wrong mask, dont you think so ?
interface Vlan10
ip address 192.168.3.1 255.255.255.128  (192  /26, as per your original email)
BB
interface vlan 10 on the host HQ has the wrong subnetmask.
You have configured the subnet mask of 255.255.255.128= /25
This means the subnet is from 192.168.3.0-127 and therefor it overlaps with the ip you try to configure on VLAN20.
Change the ip addres on vlan 10 to 192.168.3.1 255.255.255.192 should do the trick.
