isdn connection
carl_townshend
Hi all, If I have 2 isdn sites and im only making a call one way, do I still need to set up all the dialler information both ways etc
5 Replies 5
sourabhagarwal
Level 4
Level 4
if you are not expecting return traffic from the remote site, then you can go without setting dialer information else dialer information needs to be configured on both sides.
HTH, rate if it does.
amit-singh
Level 8
Level 8
Yes, the dialer information should be set on both the sides.
-amit singh
danielmassey
Hi Carl,
Its not required the set up Dialler for Both way.
Assume that u have site A & B, and we need to dial fron A to B. Its suffient to configure in A end alone.
Danny
So ,what info would I need to put in ?
