issues booting 4500x switch
jkay18041
Level 3
Level 3
I have a 4500x switch that had the IOS deleted accidently.
When booted this is what we get.
* Rom Monitor NVRAM configuration is being initialized to *
* default values. This may be because it was never initialized.*
Writing to Primary Region failed
Writing to Backup Region failed
Rommon (G) Signature verification PASSED
flash0:/codesign/rm1.dat open failure
Rommon (P) Signature verification PASSED
flash0:/codesign/rm2.dat open failure
FPGA (P) Signature verification PASSED
flash0:/codesign/fpga.dat open failure
* Welcome to Rom Monitor for WS-C4500X-16 System. *
* Copyright (c) 2008-2012 by Cisco Systems, Inc. *
* All rights reserved. *
Rom Monitor (P) Version 15.0(1r)SG6
CPU Rev: 2.2, Board Rev: 4, Board Type: 108
CPLD Mobat Rev: 2.0x4377.0xb277
Chassis: WS-C4500X-16
MAC Address : e0-2f-6d-43-16-3f
Ip Address : Not set.
Netmask : Not set.
Gateway : Not set.
TftpServer : Not set.
Non-Redundant system or peer not running IOS
System Uplinks & Linecards have been reset!!
***** The system will autoboot in 5 seconds *****
Type control-C to prevent autobooting.
Management Ethernet Link Up: 100Mb Full Duplex
******** The system will autoboot now ********
config-register = 0x102
Autobooting using BOOT variable specified file.....
Could not find a valid file in BOOT environment variable.
BOOT variable can be set from IOS. To find currently set
Rom Monitor variables, please type 'set' command.
For help on choosing a boot method, type 'confreg' command.
I've set an IP address and was able to ping a TFTP server and I am trying to load back the IOS and it loads it then reboots and all the settings including the tftp settings and IP settings are erased.
How can I get this to work again?
Thank you
9 Replies 9
I did read that post and here is what I did and it just seemed to go back to the rommon after i ran the boot tftp command.
rommon 1 >confreg
Configuration Summary :
=> console baud: 9600
=> autoboot from: commands specified in 'BOOT' environment variable
do you wish to change the configuration? y/n [n]: n
rommon 2 >set interface fa1 192.168.10.230 255.255.255.0
rommon 3 >set ip route default 192.168.10.251
rommon 4 >set
PS1=rommon ! >
RommonVer=15.0(1r)SG6
SupportedFeatures=1
ConfigReg=0x0102
IpAddr=192.168.10.230
Netmask=255.255.255.0
Broadcast=192.168.10.255
Gateway=192.168.10.251
rommon 5 >ping 192.168.10.250
Host 192.168.10.250 is alive
rommon 6 >boot tftp://192.168.10.250/cat4500e-universal.SPA.03.03.00.SG.151-1.SG.bin
Here is what happens after the boot tftp command.
Tftp Session details are ....
Filename : /cat4500e-universal.SPA.03.03.00.SG.151-1.SG.bin
IP Address : 192.168.10.230
Loading from TftpServer: 192.168.10.250
TftpBlkSize : 1468
RxDataPacket : 076525
Loaded 112337548 bytes successfully.
Checking digital signature....
[/cat4500e-universal.SPA.03.03.00.SG.151-1.SG.bin]
Digitally Signed Release Software with key version A
flash0:/codesign/ios.dat open failure
Rommon reg: 0x00084F80
Reset2Reg: 0x00004200
Image load status: 0x00000000
Winter 110 controller 0x046B54B6..0x0481E81D Size:0x002FDB9D Program Done!
Linux version 2.6.24.4.8.3.k10 (krunyan@build-lnx-005) (gcc version 4.2.1 p6 (Cisco c4.2.1-p6)) #1 SMP Sat Apr 14 23:47:37 PDT 2012
Starting System Services
Error!! POST pre-start: /flash0 is not mounted.
Error!! POST post-stop: /flash0 is not mounted.
Starting IOS Services
A Critical job [licensed] exited abnormally! Reloading the supervisor
FATAL: Module mtsmod is in use.
Please stand by while rebooting the system...
Restarting system.
Which step followed : there is
1- Change the config register to 0x2102
--Check the settings
rommon>set
--Clear the current boot variable
rommon>unset boot
rommon>confreg 0x2102
rommon>reset
if you tried that steps, then time for TAC case for RMA.
BB
In ROMMON, post the complete output to the following commands:
  • set
  • dir flash:
That, to me, means the supervisor card is dead.
Here is what I get
rommon 1 >set
PS1=rommon ! >
SupportedFeatures=1
ConfigReg=0x0102
rommon 2 >dir flash:
Invalid path flash:
usage: dir { [ bootflash: ] | [ slot0: ] | [ usb0: ] }
Please post the complete output to the command "dir bootflash:".
rommon 1 >dir
rommon 2 >dir bootflash:
ExtX super block invalid signature
Thank you for your assistance
as i mentioned earlier time for TAC and RMA Please.
BB
Contact Cisco TAC and RMA and appliance.
