Kindly help me to know
aitriy001
which  cisco  switch  has the following feature
1- PoE configrations with up to 15.4 W of PoE for all ports
2- PoE gigabit connection  , 12 Ports
3- Multicast routing IPv6
The Cisco Catalyst 3560E-12SD should suffice,
However notice, all the 12 ports here are SFP Fiber ports with Two 10G uplinks.
Mohamed
Mohamed Sobair
Level 7
Level 7
The 3560-E series provies the features you are looking for, have a look at the below link:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7078/product_data_sheet0900aecd805bac22.html
Mohamed
Is  Cisco Catalyst 3560E-12SD   or   Cisco Catalyst 3560E-12D  supply  power over fiber becouse  i will  connect it  to the  outdoor Access point
1522 AG and i need  to work without power supply
Mohamed
1522 AG and i need  to work without power suppl>
No, only copper ports provide power to the phones.  Fiber can not be used to power your phones.  So you need a switch that comes with copper ports if you need POE. If you use fiber to connect to your phones, then you need to plug the phone to the power outlet.
Reza
