Showing results forĀ
Search instead forĀ
Did you mean:Ā
LACP between Cisco and Huawei
m.pederneschi
Hi all,
I'm trying to configure a port-channel between a Cisco Cat 4507 and a Huawei switch; when I try to activate the Po on the Cisco side I got the following error:
*Jun  8 06:27:08.289: %PM-4-ERR_DISABLE: channel-misconfig error detected on Po20, putting Te1/1 in err-disable state
*Jun  8 06:27:08.293: %EC-5-UNBUNDLE: Interface Te1/1 left the port-channel Po20
*Jun  8 06:27:08.293: %PM-4-ERR_DISABLE: channel-misconfig error detected on Po20, putting Te1/2 in err-disable state
*Jun  8 06:27:08.305: %EC-5-UNBUNDLE: Interface Te1/2 left the port-channel Po20
*Jun  8 06:27:08.305: %PM-4-ERR_DISABLE: channel-misconfig error detected on Po20, putting Po20 in err-disable state
*Jun  8 06:27:08.297: %EC-5-UNBUNDLE: STANDBY:Interface Te1/1 left the port-channel Po20
*Jun  8 06:27:08.301: %PM-4-ERR_DISABLE: STANDBY:channel-misconfig error detected on Te1/1, putting Te1/1 in err-disable state
*Jun  8 06:27:08.325: %PM-4-ERR_DISABLE: STANDBY:channel-misconfig error detected on Te1/2, putting Te1/2 in err-disable state
*Jun  8 06:27:08.445: %PM-4-ERR_DISABLE: STANDBY:channel-misconfig error detected on Po20, putting Te1/1 in err-disable state
*Jun  8 06:27:08.445: %PM-4-ERR_DISABLE: STANDBY:channel-misconfig error detected on Po20, putting Te1/2 in err-disable state
*Jun  8 06:27:08.445: %PM-4-ERR_DISABLE: STANDBY:channel-misconfig error detected on Po20, putting Po20 in err-disable state
Below the configuration on the Cisco side:
interface Port-channel20
 switchport
 switchport trunk allowed vlan 1,705-707
 switchport mode trunk
 switchport nonegotiate
 flowcontrol receive on
 spanning-tree link-type point-to-point
end
interface TenGigabitEthernet1/1
 shutdown
 channel-group 20 mode active
end
interface TenGigabitEthernet1/2
 shutdown
end
and here the configuration on the Huawei Switch:
interface Eth-Trunk20
 port link-type trunk
 port trunk allow-pass vlan 705 to 707
 stp disable
 mode lacp-static
 lacp timeout fast
interface 10GE1/0/3
 eth-trunk 20
 lacp priority 16784
 device transceiver 10GBASE-COPPER
interface 10GE2/0/3
 eth-trunk 20
 lacp priority 32678
Any suggetion on the cause of this error?
I need to apply the lacp priority in order to have an active/stand-by configuration.
Many thanks,
Maurizio
agapitca19
Try to put the command channel-protocol lacp on the physical ports for Po20 then bounce them. If it still doesn't work, try removing the the command switchport nonegotiate.
***Please rate and mark the comment correct if you found it useful. Thanks***
Hi agapitca19,
thanks for your suggestion but it still doesn't work. I tried to remove on the Huawei side the lacp preempt and priority but same issue.
The port-channel goes up for some second:
*Jun  8 08:16:42.909: %EC-5-BUNDLE: Interface Te1/1 joined port-channel Po20
*Jun  8 08:16:42.997: %EC-5-BUNDLE: Interface Te1/2 joined port-channel Po20
4507-SW-1-ARM-A#
*Jun  8 08:16:42.913: %EC-5-BUNDLE: STANDBY:Interface Te1/1 joined port-channel Po20
*Jun  8 08:16:43.097: %EC-5-BUNDLE: STANDBY:Interface Te1/2 joined port-channel Po20
An then goes down.
Julio E. Moisa
Your config looks fine, except the physical interfaces has shutdown configured. Please check this link:
http://huaweis3700.weebly.com/blog/lacp-between-cisco-and-huawei
Also check the Spanning Tree configurations. Do you have Etherchannel guard configured on the Cisco device?
spanning-tree etherchannel guard misconfig
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Rex Chia
I am facing the same issue too. The problem doesn't prompts at the beginning when first connected Cisco C3560 to Huawei Switch S5720-32X-EI-AC for 4 months++, but it keep on prompting after adding and removing VLAN from VTP. Both member interfaces in the Port-Channel are being put as error-disabled, even if reset Port-Channel and Physical interfaces, it will become error-disabled again after up for certain time.
May 14 13:56:48.059 MY: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Gi0/1, putting Gi0/1 in err-disable state
May 14 13:56:48.142 MY: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Gi0/2, putting Gi0/2 in err-disable state
May 14 13:56:48.285 MY: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Po1, putting Gi0/1 in err-disable state
May 14 13:56:48.285 MY: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Po1, putting Gi0/2 in err-disable state
May 14 13:56:48.285 MY: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Po1, putting Po1 in err-disable state
May 14 13:56:49.107 MY: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
May 14 13:56:49.191 MY: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to down
May 14 13:56:49.225 MY: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel1, changed state to down
Below is the solution that Huawei provided, set "undo port trunk allow-pass vlan 1" at the Huawei switch port-channel interface :
interface Eth-Trunk3
 description Downlink to Cisco Switch
 port trunk allow-pass vlan 2 to 4094
 mode lacp
So far it has been running fine for a day at least. Still monitoring.
Feel free to share if anyone has another solution and information.
Found this post from Huawei website too.
http://support.huawei.com/enterprise/en/knowledge/EKB1000435123
