LAN/WAN Problem
oneirishpollack
I apologize if this is not the right thread.....
Can someone take a look at my setup and advise on what I am doing something wrong.
I have a comcast modem, cisco 3600 router, cisco 3500 switch, 2 computers.
I want to use the router to connect my internal network (10.1.8.0/24) to the Internet.
My internal network is: 10.1.8.0/24
My comcast IP assigned dynamically to the router interface is: 71.67.74.75
Below is the output of a 'sh run' on the 3600:
"version 12.3
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
username xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
no aaa new-model
ip subnet-zero
ip name-server 68.87.73.242
ip name-server 68.87.73.226
ip dhcp pool DHCP
import all
ip cef
interface FastEthernet1/0
description Internet
ip address dhcp
duplex auto
speed auto
no clns route-cache
interface FastEthernet3/0
description Internal LAN
ip address 10.1.8.1 255.255.255.0
duplex auto
speed auto
no clns route-cache
ip nat inside source list 100 interface FastEthernet3/0 overload
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 71.63.64.1
access-list 100 permit ip any any
line con 0
line aux 0
line vty 0 4
password 7 xxxxxxxxxxxxxxxxxxxxxxxx
login local
end"
My router can ping www.yahoo.com
My router can ping 10.1.8.103 (one pc on my network)
My node can ping 10.1.8.1 (static addressed assigned to LAN interface. (int F3/0))
My node can ping 10.1.8.100 (another pc on my network)
My node can ping 71.67.74.75 (dhcp address assigned to Internet interface. (int fa1/0))
My node cannot ping public addresses outside of my directly connected interfaces.
What am I doing wrong?
The Irish Pollack
mahmoodmkl
Level 7
Level 7
u should have ip nat outside under u r f1/0.
ip nat inside source list 100 interface FastEthernet1/0 overload
Mahmood
Richard Burts
Irish Pollack
The main issue that I see is with address translation. You do not have configured any inside interface or outside interface for NAT. I suggest that you configure the FastEthernet3/0 as the nat inside interface and FastEthernet1/0 as the nat outside interface. Do this and let us know if it works better.
[edit] and as Mahmood points out your overload is on the wrong interface.
Rick
Rick
Mark Yeates
Level 7
Level 7
The problem is that you are missing the inside and outside NAT statements under the interfaces.
Please add the following to your config:
ip nat outside
ip nat inside
no ip nat inside source list 100 interface FastEthernet3/0 overload
HTH,
Mark
You guys are great.
Thanks for the help.
