layer 3 Etherchannel
giacomo12
I am studying for CCNP switching. I am trying to configure layer 3 channel between two switches in GNS3
     Swich_A(Gi0/0-1) -------------------Switch_B(Gi0/0-1)
 Po1 -  10.1.20.1/24                                 Po1 - 10.1.20.2/24
Even though I followed the steps to configure the ports of the switches, I can not ping the IP address
of the Port-channel from one switch to the other.
Below the configuration of Switch_A and switch_B
Switch_A
interface Port-channel1
 no switchport
 ip address 10.1.20.1 255.255.255.0
interface GigabitEthernet0/0
 description port_of_Po1
 no switchport
 no ip address
 negotiation auto
 channel-group 1 mode on
interface GigabitEthernet0/1
 no switchport
 no ip address
 negotiation auto
Switch_A#show etherchannel
                Channel-group listing:
Group: 1
Group state = L3
Ports: 2   Maxports = 4
Port-channels: 1 Max Port-channels = 1
Protocol:    -
Minimum Links: 0
Switch_B
 no switchport
 ip address 10.1.20.2 255.255.255.0
 description port_to_Po1
 no switchport
 no ip address
 negotiation auto
 no switchport
 no ip address
 negotiation auto
Switch_B#show etherchannel
Group: 1
Group state = L3
Protocol:    -
Minimum Links: 0
Switch_B#show cdp neighbors detail
Device ID: Switch_A
Entry address(es):
  IP address: 10.1.20.1
Platform: Cisco ,  Capabilities: Router Switch IGMP
Interface: GigabitEthernet0/1,  Port ID (outgoing port): GigabitEthernet0/1
Holdtime : 163 sec
Switch_B#ping 10.1.20.1
Sending 5, 100-byte ICMP Echos to 10.1.20.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Switch_B#.
Where am I wrong?
Thank you
9 Replies 9
Reza Sharifi
Never used GNS before but sometimes not all the functions work the same as a regular switch.
Are ports g0/0 and 0/1 in up and up mode. "sh ip int brie" should show you that.
balaji.bandi
Try no ip cef in global command and let me know.
BB
Just to add you could also try LACP or PAGP in case it does not support ON mode in the emulator
HI,
Please share the image code in order to test in the lab. Thanks
*** Please rate all helpful responses and mark solutions***
Switch_A#show ver
Cisco IOS Software, vios_l2 Software (vios_l2-ADVENTERPRISEK9-M), Version 15.2(4.0.55)E, TEST ENGINEERING ESTG_WEEKLY BUILD, synced to END_OF_FLO_ISP
Switch_B has the same
Thank you
thats layer 2 image not layer 3 looking at it ....
so its probly not able to complete a layer 3 port-channel syntax like that with IP as its L3 feature
EDIT: Use a L3 image same config should work
@giacomo12
Your image is not supporting so you need to have a special/modified image in order to perform layer 3 functions.
Change the image to L3 and share the outputs here
why not try with IOL images- it is small and less resource required. ( compare to vIOS)
BB
