Layer 3 switch inter-vlan routing
frontechasl123
Community Member
Untitled.jpgHi All,
I connected 2 PC's to a Layer 3 Switch. Each PC is in one vlan. There is no layer2 switches & Routers. I want one PC inone Vlan to communicate with another PC in another vlan.
After doing the following below configuration, PC1 couldn't ping PC 2.
Vlan 10 ; 10.1.1.0/24
Vlan 20;  20.1.1.0/24
PC1- Vlan 10-- 10.1.1.1 ;;;;  PC1 is connected to interface FastEthernet 10 in Switch
PC2- Vlan 20-- 20.1.1.1 ;;;;  PC2 is connected to interface FastEthernet 11 in Switch
SWITCH:
Layer3(config)#vlan 10
                      name ten
Layer3(config)#vlan 20
                      name twenty
Layer3(config)#int fa0/10
                      switchport mode access
                      switchport access vlan 10
                      no sh
Layer3(config)#int fa0/11
                      switchport access vlan 20
                      no sh
Layer3(config)#int vlan 10
                      ip address 10.1.1.10 255.255.255.0
                      no sh
Layer3(config)#int vlan 20
                      ip address 20.1.1.10 255.255.255.0
                      no sh
Layer3(config)#ip routing
Pls suggest, did i miss anything
9 Replies 9
Shashank Singh
Try setting the default gatways on PCs to their respective interface vlan IP addresses. Also, try turning off the firewall (if any) on the PCs.
Cheers,
Shashank
glen.grant
Removed
johnlloyd_13
Level 11
Level 11
hi,
your VLAN 20 is using a public IP address. try to re-configure your SVI and host PC with a private IP address and test again.
For testing purposes it dowsn't matter if he uses public addresses so long as he isn't going to the internet, in which he would probably use NAT anyway, so thats not the answer to his problem although it is good practise.
You didn't actually say if your setup worked or not? Can you ping inbetween the PC's?
Do a #sh vlan to make sure you created the vlans correctly. Try a ping, what happens?
If you configured the default gateway and masks right on the PC's it should work.
Ian
johnlloyd_13
Level 11
Level 11
hi ian,
i stand corrected. i simulated this on lab and it does route or is able to ping. it must be the PC setup. it would be helpful to post his ipconfig.
No worries mate...you never go to bed without learning something new
kapathak
Is the default gateway on the PC's configured as the SVI IP of the corresponding vlans?
On PC0, the default gateway would be 10.1.1.10
On PC1, the default gateway would be 20.1.1.10
Cheers.
Thanks all for your support.
I couldn't ping one pc to another.
I cant configure default-gateway, as i this set up is done on packet tracer 5.3. There is no option to configure default-gateway in pc.
As far as configuration , did i miss any command?
hi,
you can set the default gateway by clicking on Config tab > Settings > Gateway.
