Load Balance
londint
I want to load balance over 2 lines. Apart from per destination and per packet, what else can I configure and look out for.
I need traffic to go over the 2 lines. I am runing CiscoIOS
14 Replies 14
royalblues
Level 10
Level 10
Hi friend,
You can also consider Multilink for load balancing
eg.
interface Multilink1
ip address x.x.x.x y.y.y.y
ppp multilink
ppp multilink group 1
interface Serial0/2/0
no ip address
encapsulation ppp
ppp multilink
interface Serial0/1/0
no ip address
encapsulation ppp
ppp multilink
ip route
HTH, rate if it does
Narayan
Thank you very much.
I have two different ISP connections with two different Public ip address, is there any way to configure load balancing in my router. i need to enable NAT in my router.
amit-singh
Level 8
Level 8
You can also consider the CEF load-balancing to achieve the load-balancing per destination or per-packet.
Here is a link which can tell you about the diffrent load-balancing mechanism:
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_white_paper09186a0080091d4b.shtml
HTH, Please rate if it does.
-amit singh
how can i write route for load balance. there is two different IP address scheme from two different ISPs, Can you give guidence for the configuration
emailvineet2000
Dear Sir,
eg.
ip address ipaddress subnet
ppp multilink
no ip address
encapsulation ppp
ppp multilink
no ip address
encapsulation ppp
ppp multilink
ip route
Vineet Kumar
If there is two ISP's with two different public IP's, how can i assign my two public IP's in multilink.
can i configure multilink at my side without worrying about two iSP'S configuration (ofcourse PPP at my end). and where i give nat outside command ? is it in both the serial interfaces.
Plz kindly help me.
You can't bundle 2 different ISPs into a multilink. The configuration must be identical at both ends (encapsulation ppp and ip address subnet must correspond).
Hi All
Can this config also be applied to
Interface Gigabyte0/1
No, with Gigabit interfaces, you need to implement etherchanneling.
If you are talking about using multilink on inetrface gigabyte 0/1, then no it cannot be used on this interface. It is only used on the interfaces which uses PPP as the encapsulation like serial interfaces. Ethernet interfaces uses a different encapsulation.
HTH,Please rate if it does.
-amit singh
Thank you veru much.
