Loopback interface unreachable
MrBeginner
HI ,i wold like to know about layer 2 switch loopback interface unreachable problem.
i have the 2960 lanbase switch. I would like to create loopback interface for some purpose.
i have the one vlan. let say vlan id is 10. i would like to get connectivity between vlan 10 network and loopback interface.
I understand if loopback interface and vlan 10 are different network,i need the routing function or ( router) to route each other .
But i am not sure if  i assign vlan 10 ip address to loopback interface,can loopback interface reachable to vlan 10 network ? Please correct me ..
balaji.bandi
If you like Loopback to work
you need to use VLAN 10 as transport
if the switch has VLAN 10 IP address, you need to have manual static entry for that Loopback to reach in and out.
BB
MrBeginner
Hi balaji.bandi,
can i request to explain detail ?
balaji.bandi
based on the input you have posted.
if you can VLAN 10 to Layer2 switch example switch has 10.10.10.20 IP - which can communicate with other Management VLAN (i take this 10 as management VLAN to manage the Devices) - by default you have only 1 route to go out to uplink switch
if you have Local loopback address 10.10.127.1
on the uplink switch you can have route entry ip route 10.10.127.1 to 10.10.10.20, so your Loopback is reachable. in other vlan
make sense?
BB
