MAB (or 802.1X) on C4510R+E doesn't start
rwesel
We have a cisco WS-C4510R+E Supervisor 8-E with IOS-XE Version 03.09.00.E and want to assign VLAN per MAC-Address. VLAN info should come from a Radius (FreeRadius).
Unfortunately I am stuck at the very beginning.
I have "aaa new-model" and a "radius server radtest ..." configured.
On the interface I activated 802.1x like this:
interface GigabitEthernet1/11
switchport access vlan 99
switchport mode access
access-session port-control auto
dot1x pae authenticator
spanning-tree portfast edge
end
(the same behaviour is with "mab" instead of "dot1x pae authenticator" or with both enabled)
I started debugging:
debug dot1x all
debug access-session all
debug mab all
These are the messages when I plug in a laptop in Gi1/11:
Nov 29 15:40:05: dot1x-ev:[Gi1/11] Interface state changed to UP
Nov 29 15:40:05: dot1x-ev:DOT1X Supplicant not enabled on GigabitEthernet1/11
Nov 29 15:40:05: AUTH-EVENT: [Gi1/11] Link UP
Nov 29 15:40:07: %LINK-3-UPDOWN: Interface GigabitEthernet1/11, changed state to up
Nov 29 15:40:07: AUTH-EVENT: [Gi1/11] Interface state changed to UP
Nov 29 15:40:07: AUTH-EVENT: [Gi1/11] Link UP
Nov 29 15:40:07: AUTH-EVENT: [Gi1/11] Link already UP - ignoring
Nov 29 15:40:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/11, changed state to up
The switch uses the new-style authentication mode, so as I understood I have to use IBNS2.0 with a service-policy. I already created one but it seems to me that not even the MAB/802.1X process starts.
Am I missing something? Some global setting?
Or does our platform or IOS not support this?
Thanks for your help
Stefan
It doesn't look like you are applying your ibns 2 service policy to any interfaces based on the postings above. Below is an excerpt showing ibns 2 config for MAB (monitor mode) that I am using ok on 3650s running 03.06.05E
hth
Andy
ps use debug radius for monitoring
aaa authentication dot1x default group radius
aaa authorization network default group radius
aaa accounting update newinfo periodic 5
aaa accounting identity default start-stop group radius
aaa accounting system default start-stop group radius
service-template MONITOR_MODE_SERVICE_TEMPLATE
dot1x system-auth-control
policy-map type control subscriber MONITOR_MODE_MAB_POLICY
event session-started match-all
10 class always do-until-failure
10 authenticate using mab priority 10
event authentication-failure match-first
10 terminate mab
20 authentication-restart 60
event inactivity-timeout match-all
10 clear-session
event authentication-success match-all
10 activate service-template MONITOR_MODE_SERVICE_TEMPLATE
mab
service-policy type control subscriber MONITOR_MODE_MAB_POLICY
8 Replies 8
Rolf Fischer
Level 9
Level 9
Stefan,
Some global Setting?
Have a look at the Enabling 802.1X Authentication section of the c4500 IOS XE 3.9.0E Configuration Guide:
Switch(config)# dot1x system-auth-control
Rolf
Rolf,
thanks for your reply.
But I just forgot to mention that I already did these settings.
as well as:
Any ideas else ?
And any ideas how to debug or get detailed information?
I did already:
mab logging verbose
dot1x logging verbose
but there are no helpful messages.
thx
Stefan
Strange!
I always tested with a linux laptop connecting to my test port. As stated above it seems the dot1x process doesn't start - I get only:
When I connect a windows laptop now something is going on:
AUTH-EVENT: [0022.XXXX.YYYY, Gi1/11] New LL MAC: 0022.XXXX.YYYY from Switch PI
AUTH-EVENT: [0022.XXXX.YYYY, Gi1/11] Assigned AAA ID 0x00000473
AUTH-EVENT: [0022.XXXX.YYYY, Gi1/11] Allocated new Auth Manager context (handle 0x8A000032)
AUTH-DETAIL: [0022.XXXX.YYYY, Gi1/11] Client 0022.XXXX.YYYY, Initialising Method Session Mgr IPDT Shim state to 'Not run'
My goal is to assign a VLAN to switchport regardless of the connected device (linux,windows, else ; supplicant or not ; ...) just depending on the devices MAC address. For my understanding I have to use MAB, right?
Any ideas how to achieve this ?
Not any ideas ?
Can anybody confirm if I can use MAC authentication bypass on my platform at all?
This is my environment
My hardware is:
cisco WS-C4510R+E (P5040) processor (revision 2)
Sup 8-E 10GE (SFP+), 1000BaseX (SFP)   WS-X45-SUP8-E
My Software is:
IOS-XE Software, Catalyst 4500 L3 Switch  Software (cat4500es8-UNIVERSALK9-M), Version 03.09.00.E RELEASE SOFTWARE (fc1)
"Old" interface commands don't work anymore, e.g.:
switch(config-if)#authentication port-control auto
%Command deprecated (authentication port-control auto ) - use access-session instead
switch(config-if)#authentication event fail action authorize vlan 13
Command deprecated (authentication event fail action authorize vlan 13) - use cpl config
Config mode is new style:
switch#authentication display config-mode
Current configuration mode is new-style
IBNS 2.0 Deployment Guide (from 2013) says:
http://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/identity-based-networking-services/whitepaper_C11-729965.html
Platform Support Matrix: Catalyst 4500E Sup8E + Policy Aware IBNS (New-Style) => No Support
I can't believe - legacy style doesn't work anymore - new style isn't supported - with the highest version of supervisor and newest IOS ???
I hope somebody can dissolve my confusion.
thx
Stefan
Not any ideas ?
hth
Andy
10 terminate mab
10 clear-session
mab
Hello Andy,
that did the trick.
Now "something is starting" - MAC is detected and a radius message is created.
I just have to investigate the rest of the chain, if it is working for window as well as for linux and maybe also on non cisco switches.
Thank you very much
Stefan
You are welcome Stefan. Hope the deployment goes well.
Andy
