management vlan configuration between HP and CISCO
Hello guys,
i have difficulties setting up the connectivity between an old HP switch and a new CISCO C9200L-48P-4G-E L3 switch.
The cisco switch is supposed to replace another switch in our running company environment.
First about my problems:
  • From the HP switch, i can ssh forward to any other switch except the new cisco one.
  • On the HP switch i can run "sh cdp neighbors" an see the connected cisco switch, with its configured management ip adress 192.168.1.17 - if i run the same command on the cisco switch, i dont see any connected devices
  • ping and way more important ssh doesnt work in either direction
The switches are directly connected on 4 ports.
Port 37 on the hp switch is wired with Port gigaEth1/0/1 on the cisco device.
Port 38 on the hp switch is wired with Port gigaEth1/0/2 on the cisco device.
Port 39 on the hp switch is wired with Port gigaEth1/0/3 on the cisco device.
Port 40 on the hp switch is wired with Port gigaEth1/0/4 on the cisco device.
Since the hp switch works with the other devices in the network i guess my mistake is on the cisco side
hp config:
hostname "MasterSwitch"
trunk 1-4 trk1 lacp
trunk 5-8 trk2 lacp
trunk 9-12 trk3 lacp
trunk 13-16 trk4 trunk
trunk 17-20 trk5 trunk
trunk 21-24 trk6 trunk
trunk 37-40 trk7 trunk
trunk 33-36 trk8 trunk
trunk 41-44 trk9 trunk
max-vlans 32
vlan 1
   name "Managment"
   no untagged 26-27,30-32,45,47
   untagged 25,28-29,46,48-52
   tagged Trk1-Trk9
   ip address 192.168.1.10 255.255.255.0
   exit
hp sh cdp neighbors:
 CDP neighbors information
  Port Device ID                     | Platform                     Capability
  5    38 ea a7 b0 b3 80             | HP J9775A 2530-48G Switch... S
  6    38 ea a7 b0 b3 80             | HP J9775A 2530-48G Switch... S
  7    38 ea a7 b0 b3 80             | HP J9775A 2530-48G Switch... S
  8    38 ea a7 b0 b3 80             | HP J9775A 2530-48G Switch... S
  14   T48S805EC071285A              | T48S
  21   38 ea a7 b0 33 80             | HP J9775A 2530-48G Switch... S
  22   38 ea a7 b0 33 80             | HP J9775A 2530-48G Switch... S
  23   38 ea a7 b0 33 80             | HP J9775A 2530-48G Switch... S
  24   38 ea a7 b0 33 80             | HP J9775A 2530-48G Switch... S
  37   Switch7                       | Cisco IOS Software [Fuji]... S
  38   Switch7                       | Cisco IOS Software [Fuji]... S
  39   Switch7                       | Cisco IOS Software [Fuji]... S
  40   Switch7                       | Cisco IOS Software [Fuji]... S
  45   00 0a cd 38 4d c4             |
  46   3c 18 a0 0c c2 d9             |
the cisco config:
hostname Switch7
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 ip address 192.168.1.17 255.255.255.0
 negotiation auto
interface GigabitEthernet1/0/1
 switchport trunk allowed vlan 1
 switchport mode trunk
interface Vlan1
 description In-band Management
 ipv6 enable
 ipv6 dhcp client request vendor
ip route vrf Mgmt-vrf 0.0.0.0 0.0.0.0 192.168.1.1
ip ssh time-out 60
cisco sh ip int brief
Switch7#sh ip int brief
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  192.168.1.17    YES NVRAM  up                    up
GigabitEthernet0/0     192.168.1.17    YES NVRAM  down                  down
GigabitEthernet1/0/1   unassigned      YES unset  up                    up
GigabitEthernet1/0/2   unassigned      YES unset  up                    up
GigabitEthernet1/0/3   unassigned      YES unset  up                    up
GigabitEthernet1/0/4   unassigned      YES unset  up                    up
GigabitEthernet1/0/5   unassigned      YES unset  down                  down
GigabitEthernet1/0/6   unassigned      YES unset  down                  down
cisco sh cdp neighbors:
Switch7#sh cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
Total cdp entries displayed : 0
I dont care too much about the cdp problem, i just mentioned it because it might have something to do with the connectivity issue.
Last but not least, i'm not a network specialist and just inherited the topic so please dont blame me too much for mistakes that might be obvious for you.
5 Replies 5
Seb Rupik
Hi there,
The four HP ports are an LACP trunk, you should configure the same on the Cisco:
int range gi1/0/1-4
  channel-group 1 mode active
  swichport mode trunk
  switchport trunk vlan 1
Try adding the config and see if that improves the connectivity.
Confirm the status of the port-channel on the cisco with:
show port-channel summary
cheers,
Seb.
i think you have misread the hp config.
Ports 1-12 are an LACP trunk,
Ports 37-40, where the cisco switch is connected are not.
Furthermore the command show port-channel is not recognized on the switch.
Switch7#show port?
port-security
Thanks for your effort tho :)
Hello
int vlan1
Kind Regards
Paul
i tried that but got the following error message:
Switch7(config-if)#vrf forwarding Mgmt-vrf
% Management interface VRF Mgmt-vrf supports one loopback interface only.
i tried to undo the command on the gigEth0/0 with the following error:
Switch7(config-if)#no vrf forwarding
% Management interface VRF can not be changed.
Thanks for your reply tho
vb10
1. Can you attach following commands outputs from Cisco:
-show spanning-tree
-show int vlan 1
-show ip arp
-show mac address-table
2. From HP:
show spanning-tree
show mac-address-table
3. Are you planning to bundle those 4 links into single logical link?
