11-20-2012 11:47 PM - edited 03-07-2019 10:10 AM
Good day!
I have bought DRAM MEM-2900-2Gb for 2921, and received the following error...
Validation failed for DIMM0
*****System halted*****
%SPD info: DIMM0: Invalid DIMM type (only UDIMMs are supported)
%Dump of SPD info for DIMM0:
00: 80 08 08 0E 0A 01 48 00 05 30 45 06 82 08 08 00
10: 0C 08 38 00 01 05 03 3D 45 50 45 3C 1E 3C 2D 01
20: 20 27 10 17 3C 1E 1E 00 06 3C 7F 80 18 22 0F 00
30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 13 B6
40: 7F 40 00 00 00 00 00 00 01 00 00 00 00 00 00 00
50: 00 00 00 00 00 00 00 00 00 00 00 00 00 10 19 10
60: 18 10 62 00 00 00 00 00 00 00 00 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Does it mean, that i have to bought MEM-2900-512U2.5GB, such kit, to upgrade my memory of 2921 to 2.5Gb?
And how can i use only- MEM-2900-2Gb?
11-21-2012 06:20 AM
Nobody knows how to upgrade 2921 to 2.5Gb RAM?
11-21-2012 06:33 AM
11-21-2012 06:42 AM
Ok.....I have such type of memory - MEM-2900-2Gb. but when i installed such memory in 2921, i have recieved such error while booting
here is my show hardware
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9_NPE-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 18:57 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
ROUTER_CORE_2921 uptime is 7 hours, 1 minute
System restarted at 07:37:22 UTC Wed Nov 21 2012
System image file is "flash0:c2900-universalk9_npe-mz.SPA.151-4.M4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco CISCO2921/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FCZ163220H7
2 FastEthernet interfaces
3 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
11-21-2012 07:03 AM
Are you adding the 2Gig to your existing 512 to make it 2.5Gig or repacing it to have a total of 2Gig.
try it both ways.
11-21-2012 09:54 PM
Yea, i'm adding 2Gb to existing 512, i cant replace 512Mb, cause 512Mb is integrated in motherboard of 2921...
Still cant add 2Gb memory...
12-04-2013 11:03 AM
Hi Dmitri,
Did you clear this issue?
I got similar message;
I tried to installed a DIMM 512 in 2911 router in order to have 1GB in DRAM. This DRAM was installed in 3945 and works fine but in 2911 the error message is displayed.
regards
