MPLS OSPF IGP and BGP with VSS CE
Peter Valdes
Level 3
Level 3
When converging from VSS Active switch to Standby switch, it took around 30+ seconds to access the internal routes 10.X.X.X/24 via BGP. We are using OSPF for IGP MPLS backbone and BGP.
My setup:
PPEx Route-Reflector1
MPLS PPE1 <----> CE1 VSS Active     ---
                                                              |    }10.X.X.X/24
MPLS PPE2 <----> CE2 VSS Standby ---
PPEy Route-Reflector2
Attached is the CE config and also the loggs during failover.
Failover is tested by applying the "redundancy force-switchover" on the active VSS.
LDP to BGP neighbors come up which I think is causing the long failover. OSPF works fine as I can see that the loopback stays up with minimum packet loss.
Any alternatives to shortening this failover wait time?
Moh Mogh
I see that you have nsf enabled ospf, but have you configured NSF/SSO (graceful-restart) for LDP and BGP?
I hope this links helps:
http://www.cisco.com/c/en/us/td/docs/ios/mpls/configuration/guide/12_2sy/mp_12_2sy_book/mp_ldp_grace_nsfsso.html
Mohammad
Hi Mohammad,
I will read up on the link you posted and let you know.
Thanks for the info.
Peter
