Multicast does not work between differents VLAN
Martin Arsenault
Community Member
We try to activate multicast here and it does not seems to work properly.
There is our configuration :
Core : 4506 with L3 routing
Distribution : 3750 L2 only
Access: 2950 L2 only
On the 4506 we have those commands configured :
ip multicast routing
ip pim rp-address x.x.x.x      where x.x.x.x=4506 IP address
on each VLAN, we have the command ip pim sparse-dense-mode activated.
We make our test with VLC Media player.
We are able to multicast on the same VLAN...but it does not seems to works between different vlan.
On the same VLAN we see the Networks Stream (SAP) annoucement appears in VLC (on the receiver PC), but on different VLAN, we don't see it. I've also try to force receiving by entering, on the receiver PC, the multicast address entered on VLC in the transmitter PC but that don't work.
For VLC, I've put 10 for TTL to be sure that all VLAN will be reached.
We have no access list configured on the two differents VLAN that we make our tests.
Someone can help?
Martin
23 Replies 23
Hi Jon,
The Source is x.x.12.21
The Receiver is x.x.48.210
There is not ACL on VLAN12 and VLAN48. Only ACL to limit access to VLAN1
I've paste the vlan intercace config only for VLAN12 and 48.
here is the capture requested:
From CoreJ130 x.x.1.2
COREJ130#sh run int vlan 12
Building configuration...
Current configuration : 265 bytes
interface Vlan12
ip address x.x.13.2 255.255.252.0
no ip redirects
no ip proxy-arp
ip route-cache same-interface
standby 12 ip x.x.12.1
standby 12 ip x.x.13.1 secondary
standby 12 priority 110
standby 12 preempt
end
COREJ130#sh run int vlan 48
Current configuration : 298 bytes
interface Vlan48
ip address x.x.49.2 255.255.252.0
ip helper-address x.x.52.11
no ip redirects
no ip proxy-arp
standby 48 ip x.x.48.1
standby 48 ip x.x.49.1 secondary
standby 48 priority 110
standby 48 preempt
end
COREJ130#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.115.1 to network 0.0.0.0
     172.16.0.0/23 is subnetted, 2 subnets
S       172.16.8.0 [1/0] via 192.168.252.2
C       172.16.4.0 is directly connected, Vlan164
C   192.168.115.0/24 is directly connected, Vlan777
     10.0.0.0/8 is variably subnetted, 21 subnets, 5 masks
C       10.200.252.32/29 is directly connected, Vlan300
C       10.200.252.4/30 is directly connected, Vlan251
S       10.200.64.0/20 [1/0] via 10.200.252.6
C       10.200.2.0/23 is directly connected, Vlan302
S       10.200.1.0/24 [1/0] via 10.200.252.37
C       10.200.6.0/23 is directly connected, Vlan306
C       10.200.4.0/23 is directly connected, Vlan304
C       10.200.10.0/23 is directly connected, Vlan310
C       10.200.8.0/23 is directly connected, Vlan308
C       10.200.14.0/23 is directly connected, Vlan314
C       10.200.12.0/23 is directly connected, Vlan312
C       10.200.18.0/23 is directly connected, Vlan318
C       10.200.16.0/23 is directly connected, Vlan316
C       10.200.22.0/23 is directly connected, Vlan322
C       10.200.20.0/23 is directly connected, Vlan320
C       10.200.26.0/23 is directly connected, Vlan326
C       10.200.24.0/23 is directly connected, Vlan324
C       10.200.30.0/23 is directly connected, Vlan330
C       10.200.28.0/23 is directly connected, Vlan328
C       10.200.34.0/23 is directly connected, Vlan334
C       10.200.32.0/23 is directly connected, Vlan332
     x.x.0.0/16 is variably subnetted, 25 subnets, 6 masks
S       x.x.64.0/22 [1/0] via 192.168.252.2
S       x.x.68.0/23 [1/0] via 192.168.252.2
S       x.x.72.0/24 [1/0] via 192.168.115.1
C       x.x.16.0/22 is directly connected, Vlan16
C       x.x.20.0/22 is directly connected, Vlan20
C       x.x.26.0/24 is directly connected, Vlan26
C       x.x.25.0/24 is directly connected, Vlan25
C       x.x.24.0/24 is directly connected, Vlan24
S       x.x.28.0/23 [1/0] via 192.168.116.1
S       x.x.2.0/24 [1/0] via 192.168.252.2
C       x.x.1.0/24 is directly connected, Vlan1
C       x.x.11.0/24 is directly connected, Vlan11
C       x.x.10.0/24 is directly connected, Vlan10
C       x.x.12.0/22 is directly connected, Vlan12
C       x.x.48.0/22 is directly connected, Vlan48
C       x.x.52.0/24 is directly connected, Vlan52
S       x.x.60.0/22 [1/0] via 192.168.252.2
C       x.x.33.0/26 is directly connected, Vlan33
C       x.x.32.0/24 is directly connected, Vlan32
C       x.x.41.0/24 is directly connected, Vlan41
C       x.x.40.0/26 is directly connected, Vlan401
C       x.x.44.0/24 is directly connected, Vlan44
C       x.x.40.248/29 is directly connected, Vlan406
C       x.x.40.240/29 is directly connected, Vlan405
C       x.x.40.224/28 is directly connected, Vlan404
C   192.168.2.0/24 is directly connected, Vlan192
C   192.168.252.0/24 is directly connected, Vlan252
C   192.168.116.0/24 is directly connected, Vlan116
S*   0.0.0.0/0 [1/0] via 192.168.115.1
From CoreD003 x.x.1.3
CORED003#sh run int vlan 12
Current configuration : 220 bytes
interface Vlan12
ip address x.x.13.3 255.255.252.0
no ip redirects
no ip proxy-arp
end
CORED003#sh run int vlan 48
Current configuration : 253 bytes
interface Vlan48
ip address x.x.49.3 255.255.252.0
no ip redirects
no ip proxy-arp
end
CORED003#sh ip route
     172.16.0.0/23 is subnetted, 1 subnets
     10.0.0.0/8 is variably subnetted, 19 subnets, 3 masks
S       10.200.1.0/24 [1/0] via x.x.1.2
     x.x.0.0/16 is variably subnetted, 20 subnets, 6 masks
Martin
What ip address are you actually using for the RP ?
Jon
Jon,
RP address is x.x.1.2. It's configured on the two core switch.
Martin
Is that address assigned to the vlan 1 interface ? You said you had an acl on the vlan 1 interface didn't you ?
If the rp is the address of vlan 1 interface and the acl is applied to the vlan interface could you temporarily remove the acl of both vlan interfaces and retest.
*** Edit - if this does work then can you clarify which switch is HSRP active for vlan 1 ie. is it the same switch that is active for the src/dst multicast vlans.
Jon
Hi Jon,
yes, x.x.1.2 is the VLAN1 interface IP address on the CoreJ130 Switch. This switch is the HSRP Active and it's the same active switch for vlan12 and 48 (src/dst)
I've removed the ACL on VLAN 1 for testing purpose and still not works. There is no acl on vlan 12(src) and 48(dst).
Martin
Have you enabled pim on the vlan 1 interface that is the RP ie.
int vlan 1
Jon
Jon, you are the king! It working pretty fine now that I have ip pim sparse-dense-mode activated on VLAN 1 on both Core Switch. I forgot this command on the VLAN1 interface. I set this command on all interfaces, but I had not thought the VLAN1. I understand that it is required because the RP is on that VLAN.
Thank you for your help and patience! It's very appreciated!
Martin Arsenault
Martin
Well, i'm glad we finally got that one sorted, i was running out of ideas
Thanks for the rating.
Jon
runinorte
Visitor
I have the same problem... https://supportforums.cisco.com/thread/2251574
I need help.
Thanks.
