Multicast does not work between differents VLAN
Martin Arsenault
Community Member
We try to activate multicast here and it does not seems to work properly.
There is our configuration :
Core : 4506 with L3 routing
Distribution : 3750 L2 only
Access: 2950 L2 only
On the 4506 we have those commands configured :
ip multicast routing
ip pim rp-address x.x.x.x      where x.x.x.x=4506 IP address
on each VLAN, we have the command ip pim sparse-dense-mode activated.
We make our test with VLC Media player.
We are able to multicast on the same VLAN...but it does not seems to works between different vlan.
On the same VLAN we see the Networks Stream (SAP) annoucement appears in VLC (on the receiver PC), but on different VLAN, we don't see it. I've also try to force receiving by entering, on the receiver PC, the multicast address entered on VLC in the transmitter PC but that don't work.
For VLC, I've put 10 for TTL to be sure that all VLAN will be reached.
We have no access list configured on the two differents VLAN that we make our tests.
Someone can help?
Martin
Martin
Have you enabled pim on the vlan 1 interface that is the RP ie.
int vlan 1
Jon
23 Replies 23
Jon Marshall
Martin
What multicast group number are you using ?
Also as a quick test to make sure it is not something else what happens if you try dense mode rather than sparse mode, does it work then ?
Jon
Edison Ortiz
Martin,
Can you provide the show ip mroute output from the 4506 switch?
Hi all,
Thanks for your fast reply. It's very appreciated.
I've made the test in Dense-mode and it's working. So why in Sparse-Dense-Mode that does not work ?
The transmitter PC is on VLAN12 and the receiver is on VLAN48
Here is the capture in Dense-mode for sh ip mroute 226.6.6.6
COREJ130#sh ip mroute 226.6.6.6
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report, Z - Multicast Tunnel
       Y - Joined MDT-data group, y - Sending to MDT-data group
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 226.6.6.6), 00:36:44/00:02:51, RP x.x.x.x, flags: SJC
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    Vlan48, Forward/Dense, 00:00:09/00:00:00
    Vlan12, Forward/Dense, 00:28:52/00:00:00
(y.y.y.y, 226.6.6.6), 00:00:16/00:02:56, flags: T
  Incoming interface: Vlan12, RPF nbr 0.0.0.0
    Vlan48, Forward/Dense, 00:00:09/00:00:00, H
Where
x.x.x.x = 4506 Ip address
y.y.y.y = transmitter PC ip address
There is the capture in Sparse-Dense-mode for sh ip mroute 226.6.6.6
(*, 226.6.6.6), 00:39:56/00:02:40, RP x.x.x.x, flags: SP
  Outgoing interface list: Null
(y.y.y.y, 226.6.6.6), 00:03:28/00:02:55, flags: PT
Where
Thanks for your help.
Martin
Do you have multiple Core switches?
If so, which switch is running the RP?
It could be the receivers were joining the mcast tree to a different RP.
On the 2nd output, it indicates the S,G is pruned due to SPT-bit set.
With dense, it will flood every single switch and that's why it is working.
Hi Edison,
We have two core switch running HSRP : Hostname are CoreJ130 & CoreD003.
We also use PVST mode to feed each distribution switch (3750). Each 3750 have one link to CoreD003 and another link to CoreJ130.
The captures sent earlier are from the CoreJ130 and the IP listed x.x.x.x are the CoreJ130 IP address. On the CoreD003 switch, we have those commands configured :
ip multicast-routing
ip pim rp-address x.x.x.x     where x.x.x.x is the CoreJ130 address.
We also have ip pim sparse-dense-mode on all VLAN interface on the CoreD003 switch.
So it appears that we have only one RP. The two core switch has the same RP address configured pointing to the CoreJ130 core switch.
Martin
Can you confirm that both core switches have -
1) the rp address configured (sounds like it does)
2) ip pim sparse-dense-mode under the L3 vlan interfaces on both core switches.
Jon
Hi Jon,
I confirm :
  • Both Core switch have ip pim rp-address x.x.x.x --> x.x.x.x = CoreJ130 ip address.
  • Both VLAN interfaces (on CoreJ130 and CoreD003) have ip pim sparse-dense-mode configured.
Martin
On the HSRP setup, both Vlans are set to the same physical switch as the primary HSRP?
I'm assuming the RP is the loopback from the Core switch, can you ping the loopback from the other Core switch?
You didn't mentioned any routing between them.
HSRP is configured in this way :
x.x.x.2 CoreJ130
x.x.x.3 CodeD003
x.x.x.1 HRSP address
VLAN are on the same physical switch / primary HSRP (x.x.x.2).
There is a trunk configured between the two core switch. There is no routing between core switch.
There is no loopback interface created on core switch. Does it requires a loopback interface? Does the RP address must be a loopback interface ?
Can you just confirm that you can ping the RP address from the core switch that does not have the actual RP address interface on it ?
Jon
Yes, I confirm that I can ping RP address from the CoreD003.
Martin
Sorry, should have been more specific, can you ping the RP address on the RP switch using the source IP address of the vlan 12 interface ?
Jon
Jon,
From the PC on the VLAN12 I can ping the CoreJ130 (x.x.x.2) but I cannot from the PC on VLAN48 because there is an ACL that limit access to CoreSwitch. I made the test from my PC that have access to CoreSwitch.
Do I have to create a loopback interface that can be reached from all PC in our network and define it as the RP ?
Is the RP must be visible from all network ?
Martin
No the PCs do not need to be able to route to the RP just the actual routers and there is no requirement that the RP be a loopback address but it usually is because if you use an interface and that interface fails you have lost the RP whereas if you use a loopback that interface is always up as long as the switch.
Can you post -
1) vlan interface configuration from both core switches
2) if there are acls applied to interfaces can you post those too
3) "sh ip route" from both core switches
4) specify the IP address of the source and receiver
Jon
