Multicast Over Vlans - Not Working
Hello All,
I've multicast issue, when i use different vlan.
The group adress is 239.192.1.1
On 3850 :
I've enable IP PIM sparse mode enable on INT VLAN 7 ET VLAN 3
RP adresse10.1.8.254
On SG500 L2 :
Ip igmp snooping only enable
here is the config on the 3850 and some multicast command in order to debug:
CORE#sh ip int brief
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  unassigned      YES NVRAM  up                    up
Vlan2                  10.1.1.254      YES NVRAM  up                    up
Vlan3                  10.1.2.254      YES NVRAM  up                    up
Vlan4                  10.1.5.254      YES NVRAM  up                    up
Vlan5                  10.1.6.254      YES NVRAM  up                    up
Vlan6                  10.1.7.254      YES NVRAM  up                    up
Vlan7                  10.1.8.254      YES NVRAM  up                    up
Vlan8                  10.1.9.254      YES NVRAM  up                    up
Vlan9                  10.1.10.254     YES NVRAM  up                    up
Vlan10                 10.1.11.254     YES NVRAM  up                    up
GigabitEthernet0/0     unassigned      YES unset  down                  down
GigabitEthernet1/0/1   unassigned      YES unset  down                  down
GigabitEthernet1/0/2   unassigned      YES unset  administratively down down
GigabitEthernet1/0/3   unassigned      YES unset  administratively down down
GigabitEthernet1/0/4   unassigned      YES unset  administratively down down
GigabitEthernet1/0/5   unassigned      YES unset  administratively down down
GigabitEthernet1/0/6   unassigned      YES unset  administratively down down
GigabitEthernet1/0/7   unassigned      YES unset  administratively down down
GigabitEthernet1/0/8   unassigned      YES unset  administratively down down
GigabitEthernet1/0/9   unassigned      YES unset  administratively down down
GigabitEthernet1/0/10  unassigned      YES unset  up                    up
Te1/1/1                10.92.255.22    YES NVRAM  up                    up
Te1/1/2                unassigned      YES unset  up                    up
Te1/1/3                unassigned      YES unset  up                    up
Te1/1/4                unassigned      YES unset  administratively down down
Tunnel0                10.1.8.254      YES unset  up                    up
Tunnel1                10.1.8.254      YES unset  up                    up
CORE#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 10.92.255.21 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 10.92.255.21
      10.0.0.0/8 is variably subnetted, 20 subnets, 4 masks
C        10.1.1.0/24 is directly connected, Vlan2
L        10.1.1.254/32 is directly connected, Vlan2
C        10.1.2.0/24 is directly connected, Vlan3
L        10.1.2.254/32 is directly connected, Vlan3
C        10.1.4.0/23 is directly connected, Vlan4
L        10.1.5.254/32 is directly connected, Vlan4
C        10.1.6.0/24 is directly connected, Vlan5
L        10.1.6.254/32 is directly connected, Vlan5
C        10.1.7.0/24 is directly connected, Vlan6
L        10.1.7.254/32 is directly connected, Vlan6
C        10.1.8.0/24 is directly connected, Vlan7
L        10.1.8.254/32 is directly connected, Vlan7
C        10.1.9.0/24 is directly connected, Vlan8
L        10.1.9.254/32 is directly connected, Vlan8
C        10.1.10.0/24 is directly connected, Vlan9
L        10.1.10.254/32 is directly connected, Vlan9
C        10.1.11.0/24 is directly connected, Vlan10
L        10.1.11.254/32 is directly connected, Vlan10
C        10.92.255.20/30 is directly connected, TenGigabitEthernet1/1/1
L        10.92.255.22/32 is directly connected, TenGigabitEthernet1/1/1
CORE#sh int vlan 7
Vlan7 is up, line protocol is up
  Hardware is Ethernet SVI, address is cc5a.5383.1067 (bia cc5a.5383.1067)
  Internet address is 10.1.8.254/24
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 1/255, rxload 7/255
  Keepalive not supported
  Last input 00:00:00, output never, output hang never
  Input queue: 0/75/20/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 30277000 bits/sec, 2789 packets/sec
  5 minute output rate 28000 bits/sec, 1 packets/sec
     370430248 packets input, 503272111747 bytes, 0 no buffer
     Received 0 broadcasts (10 IP multicasts)
     416819 packets output, 95619968 bytes, 0 underruns
     0 output errors, 2 interface resets
     0 unknown protocol drops
CORE#sh int vlan 3
Vlan3 is up, line protocol is up
  Internet address is 10.1.2.254/24
  Last input 00:00:03, output never, output hang never
  5 minute output rate 57000 bits/sec, 4 packets/sec
     3435540 packets input, 1945286581 bytes, 0 no buffer
     Received 0 broadcasts (3 IP multicasts)
     4778213 packets output, 6015209728 bytes, 0 underruns
CORE#
CORE#
CORE#
CORE#sh ip pim rp
Group: 239.192.1.1, RP: 10.1.8.254, next RP-reachable never
Group: 239.255.255.255, RP: 10.1.8.254, next RP-reachable never
Group: 239.255.255.254, RP: 10.1.8.254, next RP-reachable never
Group: 239.255.255.250, RP: 10.1.8.254, next RP-reachable never
Group: 239.192.0.1, RP: 10.1.8.254, next RP-reachable never
Group: 224.0.1.40, RP: 10.1.8.254, next RP-reachable never
CORE#
CORE#
CORE#sh int trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi1/0/47    on               802.1q         trunking      1
Gi1/0/48    on               802.1q         trunking      999
Te1/1/2     on               802.1q         trunking      999
Te1/1/3     on               802.1q         trunking      999
Port        Vlans allowed on trunk
Gi1/0/47    1-10,30,999
Gi1/0/48    1-10,30,999
Te1/1/2     1-10,30,999
Te1/1/3     1-10,30,999
Port        Vlans allowed and active in management domain
Te1/1/2     1-10,30,999
Te1/1/3     1-10,30,999
Port        Vlans in spanning tree forwarding state and not pruned
Te1/1/2     1-10,30,999
Te1/1/3     1-10,30,999
CORE#
CORE#
CORE#sh ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry, E - Extranet,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report,
       Z - Multicast Tunnel, z - MDT-data group sender,
       Y - Joined MDT-data group, y - Sending to MDT-data group,
       G - Received BGP C-Mroute, g - Sent BGP C-Mroute,
       N - Received BGP Shared-Tree Prune, n - BGP C-Mroute suppressed,
       Q - Received BGP S-A Route, q - Sent BGP S-A Route,
       V - RD & Vector, v - Vector, p - PIM Joins on route,
       x - VxLAN group
Outgoing interface flags: H - Hardware switched, A - Assert winner, p - PIM Join
 Timers: Uptime/Expires
 Interface state: Interface, Next-Hop or VCD, State/Mode
239.192.1.1), 13:49:06/00:02:29, RP 10.1.8.254, flags: SJCL
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    Vlan3, Forward/Sparse, 01:36:32/00:02:29
    Vlan7, Forward/Sparse, 13:20:02/00:02:08
(*, 239.255.255.255), 1d08h/stopped, RP 10.1.8.254, flags: SJC
    Vlan3, Forward/Sparse, 01:59:29/00:02:30
    Vlan7, Forward/Sparse, 1d07h/00:02:10
(10.1.2.100, 239.255.255.255), 01:59:02/00:01:09, flags: T
  Incoming interface: Vlan3, RPF nbr 0.0.0.0
    Vlan7, Forward/Sparse, 01:59:02/00:02:10
(10.1.8.1, 239.255.255.255), 1d07h/00:02:45, flags: T
  Incoming interface: Vlan7, RPF nbr 0.0.0.0
(10.1.8.100, 239.255.255.255), 1d07h/00:01:06, flags: JT
(*, 239.255.255.254), 01:59:30/00:02:35, RP 10.1.8.254, flags: SJC
    Vlan3, Forward/Sparse, 01:59:29/00:02:35
(*, 239.255.255.250), 1d08h/00:02:52, RP 10.1.8.254, flags: SJC
    Vlan3, Forward/Sparse, 01:59:29/00:02:33
    Vlan6, Forward/Sparse, 1d08h/00:02:52
(*, 239.192.0.1), 01:59:27/00:02:36, RP 10.1.8.254, flags: SJCL
    Vlan3, Forward/Sparse, 01:59:27/00:02:36
(*, 224.0.1.40), 1d08h/00:02:51, RP 10.1.8.254, flags: SJCL
    Vlan6, Forward/Sparse, 1d08h/00:02:51
CORE#sh ip igmp membership
Flags: A  - aggregate, T - tracked
       L  - Local, S - static, V - virtual, R - Reported through v3
       I - v3lite, U - Urd, M - SSM (S,G) channel
       1,2,3 - The version of IGMP, the group is in
Channel/Group-Flags:
       / - Filtering entry (Exclude mode (S,G), Include mode (G))
Reporter:
       <mac-or-ip-address> - last reporter if group is not explicitly tracked
       <n>/<m>      - <n> reporter in include mode, <m> reporter in exclude
 Channel/Group                  Reporter        Uptime   Exp.  Flags  Interface
 *,239.192.1.1                  10.1.2.254      01:37:06 02:56 2LA    Vl3
 *,239.192.1.1                  10.1.8.100      13:20:36 02:39 2A     Vl7
 *,239.255.255.255              10.1.2.11       02:00:04 02:56 2A     Vl3
 *,239.255.255.255              10.1.8.100      1d07h    02:33 2A     Vl7
 *,239.255.255.254              10.1.2.20       02:00:04 02:56 2A     Vl3
 *,239.255.255.250              10.1.2.100      02:00:04 02:59 2A     Vl3
 *,239.255.255.250              10.1.7.2        1d08h    02:18 2A     Vl6
 *,239.192.0.1                  10.1.2.254      02:00:01 02:03 2LA    Vl3
 *,224.0.1.40                   10.1.7.254      1d08h    02:17 2LA    Vl6
I noticed that in the sh ip mroute i've (*,G) and not  (S,G):
(*, 239.192.1.1), 13:49:06/00:02:29, RP 10.1.8.254, flags: SJCL
BUT NOT
( IP player, 239.192.1.1) 13:49:06/00:02:29, RP 10.1.8.254, flags: SJCL
  Incoming interface: VLAN 7, RPF nbr 0.0.0.0
Thanks for your help.
37 Replies 37
Sorry i've just to read some explanation about RPF and maybe you asked me ip rpf with ip of the player who doesnt works 10.1.2.100.
CORE#sh ip rpf 10.1.2.100
RPF information for ? (10.1.2.100)
  RPF interface: Vlan3
  RPF neighbor: ? (10.1.2.100) - directly connected
  RPF route/mask: 10.1.2.0/24
  RPF type: multicast (connected)
  Doing distance-preferred lookups across tables
  RPF topology: ipv4 multicast base
Here is the same command with the player where the stream is working.
CORE#sh ip rpf 10.1.8.100
RPF information for ? (10.1.8.100)
  RPF interface: Vlan7
  RPF neighbor: ? (10.1.8.100) - directly connected
  RPF route/mask: 10.1.8.0/24
Hello Paul
here is routing table:
CORE#sh ip rout
hello,
Any ideas guys?
Abdel
Hello
To summarize, You have a valid route back to the Mc source from the access switch even though the mroute count state you do have RPF failures?
Have you checked if its not the host thats the problem? - Have you tried swapping the hosts around between vlan3 -7 and tested?
res
Paul
Kind Regards
Paul
Hello Paul,
The issut is not on the player host.
Indeed as is said before when i take the  player who doesnt works and plug it direclty on the core switch on vlan 3 the stream works therefore the player is working.
I've an issue only when i use the access switch whi is trunked with core this is why maybe I've something wrong on the settings in the SG500 switch.
thanks
Abdel
Hello
Can you enable the following please on the SG500 switch:
igmp snooping queirer
or
ip igmp snooping vlan 3 mrouter interface ( trunk interface)
res
Paul
Kind Regards
Paul
Hello Paul,
thanks for your help.
Here is the command I've on the switch about IGMP:
SW-EST-1#sh ip igmp snooping
  cpe                  customer premises equipment.
  groups               Group of multicast addresses learned by IGMP snooping
  interface            IGMP snooping interface information
  mrouter              IGMP snooping multicast routers interfaces
  multicast-tv         multicast transmissions from a vlan
SW-EST-1#sh ip igmp snooping interface 3
IGMP Snooping is globally enabled
IGMP Snooping Querier is globally enabled
VLAN 3
  IGMP Snooping is enabled
  IGMP snooping last immediate leave: disable
  Automatic learning of Multicast router ports is enabled
  IGMP Snooping Querier is disabled
  IGMP Snooping Querier operation state: is not running
  IGMP Snooping Querier version: 2
  IGMP Snooping Querier election is enabled
  IGMP Snooping Querier address :
  IGMP snooping robustness: admin 2  oper 2
  IGMP snooping query interval: admin 125 sec oper 125 sec
  IGMP snooping query maximum response: admin 10 sec oper 10 sec
  IGMP snooping last member query counter: admin 2 (default) oper 2
  IGMP snooping last member query interval: admin 1000 msec oper 1000 msec
Groups that are in IGMP version 2 compatibility mode:
Groups that are in IGMP version 1 compatibility mode:
SW-EST-1#sh ip igmp snooping mrouter
Vlan        Dynamic               Static             Forbidden
  3         gi1/1/50
  6         gi1/1/50             gi1/1/50
  7         gi1/1/50
  8
  9
 999
SW-EST-1#sh ip igmp snooping interface 7
VLAN 7
Thks
Hello
so please enable  -
conf t
 ip igmp snooping querier
res
Paul
Kind Regards
Paul
Already done last week and it doesnt change anything.
as you have noticed querier is not enable also for vlan 7 and it works.
i've enable it
SW-EST-1(config)#ip igmp snooping vlan 3 querier
SW-EST-1(config)#exi
VLAN 3
  IGMP Snooping Querier is enabled
  IGMP Snooping Querier operation state: is running
regards
hello Paul,
I'll try to do port mirroring trace in order to have all the information.
If i understand you need a port mirroring from the Server who sent multicast and also from the VLC client on vlan 3 who ask the stream.
DO you need something else?
Hello
Lets summarise this:
  1. Host in vlan 7 on that switch works but host in vlan 3 doesn't- but both work in their own vlans from core switch?
  2. You have enabled snooping - igmp querier or mrouter on the host switch ?
  3. Ip routing is disabled on the host switch
  4. mroute count show rpf failures but you say rpf is valid
  5. If you attach a non mc host to a access port in vlan 3 on that host switch it works fine
res
Paul
Kind Regards
Paul
Hello
Aplogies I Didn't make myself clear perform this on the switch first closest to the host then the router
sh ip rpf 10.1.8.254
then follow the next hop of the received mc via the route table it should show a difference regards the rpf failure
sh ip route
res
paul
Kind Regards
Paul
If you do a "ping 239.192.1.1 source vlan7 repeat 5" from the Core you get the S,G ?
Also please try to enable "ip sap listen" under SVI VL7 in the core.
Just to remember that i've the issue only on VLAN3 or all other VLAN different of VLAN7.
you are right when I ping from vlan to 239.192.1.1 i can found the (S,G).
Can you confirm that "S"adress should be the SVI of the VLAN and not the IP of the player.
Thks
CORE(config-if)#exit
CORE#
CORE#sh ip sap
SAP Cache - 3 entries
  ChC)rie 25
  HD1
  L'Equipe 21
CORE#ping 239.192.1.1 source vlan 7 repeat 5
Sending 5, 100-byte ICMP Echos to 239.192.1.1, timeout is 2 seconds:
Packet sent with a source address of 10.1.8.254
CORE#ping 239.192.1.1 source vlan 3 repeat 5
Packet sent with a source address of 10.1.2.254
Reply to request 0 from 10.1.8.1, 1 ms
Reply to request 0 from 10.1.8.1, 10 ms....
CORE#sh ip mroute
       x - VxLAN group
(*, 239.192.1.1), 05:28:28/stopped, RP 10.1.8.254, flags: SJC
    Vlan7, Forward/Sparse, 00:14:14/00:02:02
    Vlan3, Forward/Sparse, 05:28:28/00:02:49
(10.1.2.254, 239.192.1.1), 00:00:13/00:02:54, flags: JT
    Vlan7, Forward/Sparse, 00:00:13/00:02:46, A
(*, 239.255.255.255), 05:52:09/stopped, RP 10.1.8.254, flags: SJCL
    Vlan7, Forward/Sparse, 05:51:57/00:02:05
    Vlan3, Forward/Sparse, 05:52:09/00:02:58
(10.1.8.100, 239.255.255.255), 05:50:45/00:02:39, flags: LT
    Vlan3, Forward/Sparse, 05:50:45/00:02:58
(10.1.2.100, 239.255.255.255), 05:50:49/00:02:45, flags: LT
    Vlan7, Forward/Sparse, 05:50:49/00:02:05
(10.1.8.1, 239.255.255.255), 05:51:10/00:01:38, flags: LT
    Vlan3, Forward/Sparse, 05:51:10/00:02:58
(*, 239.255.255.254), 05:52:11/00:02:49, RP 10.1.8.254, flags: SJC
    Vlan3, Forward/Sparse, 05:52:09/00:02:49
(*, 239.255.255.250), 05:52:11/00:02:53, RP 10.1.8.254, flags: SJC
    Vlan3, Forward/Sparse, 05:52:09/00:02:53
(*, 224.2.127.254), 00:10:29/00:02:50, RP 10.1.8.254, flags: SJCL
    Vlan3, Forward/Sparse, 00:10:05/00:02:50
    Vlan7, Forward/Sparse, 00:10:29/00:02:08
(*, 224.0.1.40), 05:52:11/00:02:54, RP 10.1.8.254, flags: SJCL
    Vlan3, Forward/Sparse, 05:52:09/00:02:54
