Multicast Over Vlans - Not Working
Hello All,
I've multicast issue, when i use different vlan.
The group adress is 239.192.1.1
On 3850 :
I've enable IP PIM sparse mode enable on INT VLAN 7 ET VLAN 3
RP adresse10.1.8.254
On SG500 L2 :
Ip igmp snooping only enable
here is the config on the 3850 and some multicast command in order to debug:
CORE#sh ip int brief
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  unassigned      YES NVRAM  up                    up
Vlan2                  10.1.1.254      YES NVRAM  up                    up
Vlan3                  10.1.2.254      YES NVRAM  up                    up
Vlan4                  10.1.5.254      YES NVRAM  up                    up
Vlan5                  10.1.6.254      YES NVRAM  up                    up
Vlan6                  10.1.7.254      YES NVRAM  up                    up
Vlan7                  10.1.8.254      YES NVRAM  up                    up
Vlan8                  10.1.9.254      YES NVRAM  up                    up
Vlan9                  10.1.10.254     YES NVRAM  up                    up
Vlan10                 10.1.11.254     YES NVRAM  up                    up
GigabitEthernet0/0     unassigned      YES unset  down                  down
GigabitEthernet1/0/1   unassigned      YES unset  down                  down
GigabitEthernet1/0/2   unassigned      YES unset  administratively down down
GigabitEthernet1/0/3   unassigned      YES unset  administratively down down
GigabitEthernet1/0/4   unassigned      YES unset  administratively down down
GigabitEthernet1/0/5   unassigned      YES unset  administratively down down
GigabitEthernet1/0/6   unassigned      YES unset  administratively down down
GigabitEthernet1/0/7   unassigned      YES unset  administratively down down
GigabitEthernet1/0/8   unassigned      YES unset  administratively down down
GigabitEthernet1/0/9   unassigned      YES unset  administratively down down
GigabitEthernet1/0/10  unassigned      YES unset  up                    up
Te1/1/1                10.92.255.22    YES NVRAM  up                    up
Te1/1/2                unassigned      YES unset  up                    up
Te1/1/3                unassigned      YES unset  up                    up
Te1/1/4                unassigned      YES unset  administratively down down
Tunnel0                10.1.8.254      YES unset  up                    up
Tunnel1                10.1.8.254      YES unset  up                    up
CORE#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 10.92.255.21 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 10.92.255.21
      10.0.0.0/8 is variably subnetted, 20 subnets, 4 masks
C        10.1.1.0/24 is directly connected, Vlan2
L        10.1.1.254/32 is directly connected, Vlan2
C        10.1.2.0/24 is directly connected, Vlan3
L        10.1.2.254/32 is directly connected, Vlan3
C        10.1.4.0/23 is directly connected, Vlan4
L        10.1.5.254/32 is directly connected, Vlan4
C        10.1.6.0/24 is directly connected, Vlan5
L        10.1.6.254/32 is directly connected, Vlan5
C        10.1.7.0/24 is directly connected, Vlan6
L        10.1.7.254/32 is directly connected, Vlan6
C        10.1.8.0/24 is directly connected, Vlan7
L        10.1.8.254/32 is directly connected, Vlan7
C        10.1.9.0/24 is directly connected, Vlan8
L        10.1.9.254/32 is directly connected, Vlan8
C        10.1.10.0/24 is directly connected, Vlan9
L        10.1.10.254/32 is directly connected, Vlan9
C        10.1.11.0/24 is directly connected, Vlan10
L        10.1.11.254/32 is directly connected, Vlan10
C        10.92.255.20/30 is directly connected, TenGigabitEthernet1/1/1
L        10.92.255.22/32 is directly connected, TenGigabitEthernet1/1/1
CORE#sh int vlan 7
Vlan7 is up, line protocol is up
  Hardware is Ethernet SVI, address is cc5a.5383.1067 (bia cc5a.5383.1067)
  Internet address is 10.1.8.254/24
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 1/255, rxload 7/255
  Keepalive not supported
  Last input 00:00:00, output never, output hang never
  Input queue: 0/75/20/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 30277000 bits/sec, 2789 packets/sec
  5 minute output rate 28000 bits/sec, 1 packets/sec
     370430248 packets input, 503272111747 bytes, 0 no buffer
     Received 0 broadcasts (10 IP multicasts)
     416819 packets output, 95619968 bytes, 0 underruns
     0 output errors, 2 interface resets
     0 unknown protocol drops
CORE#sh int vlan 3
Vlan3 is up, line protocol is up
  Internet address is 10.1.2.254/24
  Last input 00:00:03, output never, output hang never
  5 minute output rate 57000 bits/sec, 4 packets/sec
     3435540 packets input, 1945286581 bytes, 0 no buffer
     Received 0 broadcasts (3 IP multicasts)
     4778213 packets output, 6015209728 bytes, 0 underruns
CORE#
CORE#
CORE#
CORE#sh ip pim rp
Group: 239.192.1.1, RP: 10.1.8.254, next RP-reachable never
Group: 239.255.255.255, RP: 10.1.8.254, next RP-reachable never
Group: 239.255.255.254, RP: 10.1.8.254, next RP-reachable never
Group: 239.255.255.250, RP: 10.1.8.254, next RP-reachable never
Group: 239.192.0.1, RP: 10.1.8.254, next RP-reachable never
Group: 224.0.1.40, RP: 10.1.8.254, next RP-reachable never
CORE#
CORE#
CORE#sh int trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi1/0/47    on               802.1q         trunking      1
Gi1/0/48    on               802.1q         trunking      999
Te1/1/2     on               802.1q         trunking      999
Te1/1/3     on               802.1q         trunking      999
Port        Vlans allowed on trunk
Gi1/0/47    1-10,30,999
Gi1/0/48    1-10,30,999
Te1/1/2     1-10,30,999
Te1/1/3     1-10,30,999
Port        Vlans allowed and active in management domain
Te1/1/2     1-10,30,999
Te1/1/3     1-10,30,999
Port        Vlans in spanning tree forwarding state and not pruned
Te1/1/2     1-10,30,999
Te1/1/3     1-10,30,999
CORE#
CORE#
CORE#sh ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry, E - Extranet,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report,
       Z - Multicast Tunnel, z - MDT-data group sender,
       Y - Joined MDT-data group, y - Sending to MDT-data group,
       G - Received BGP C-Mroute, g - Sent BGP C-Mroute,
       N - Received BGP Shared-Tree Prune, n - BGP C-Mroute suppressed,
       Q - Received BGP S-A Route, q - Sent BGP S-A Route,
       V - RD & Vector, v - Vector, p - PIM Joins on route,
       x - VxLAN group
Outgoing interface flags: H - Hardware switched, A - Assert winner, p - PIM Join
 Timers: Uptime/Expires
 Interface state: Interface, Next-Hop or VCD, State/Mode
239.192.1.1), 13:49:06/00:02:29, RP 10.1.8.254, flags: SJCL
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    Vlan3, Forward/Sparse, 01:36:32/00:02:29
    Vlan7, Forward/Sparse, 13:20:02/00:02:08
(*, 239.255.255.255), 1d08h/stopped, RP 10.1.8.254, flags: SJC
    Vlan3, Forward/Sparse, 01:59:29/00:02:30
    Vlan7, Forward/Sparse, 1d07h/00:02:10
(10.1.2.100, 239.255.255.255), 01:59:02/00:01:09, flags: T
  Incoming interface: Vlan3, RPF nbr 0.0.0.0
    Vlan7, Forward/Sparse, 01:59:02/00:02:10
(10.1.8.1, 239.255.255.255), 1d07h/00:02:45, flags: T
  Incoming interface: Vlan7, RPF nbr 0.0.0.0
(10.1.8.100, 239.255.255.255), 1d07h/00:01:06, flags: JT
(*, 239.255.255.254), 01:59:30/00:02:35, RP 10.1.8.254, flags: SJC
    Vlan3, Forward/Sparse, 01:59:29/00:02:35
(*, 239.255.255.250), 1d08h/00:02:52, RP 10.1.8.254, flags: SJC
    Vlan3, Forward/Sparse, 01:59:29/00:02:33
    Vlan6, Forward/Sparse, 1d08h/00:02:52
(*, 239.192.0.1), 01:59:27/00:02:36, RP 10.1.8.254, flags: SJCL
    Vlan3, Forward/Sparse, 01:59:27/00:02:36
(*, 224.0.1.40), 1d08h/00:02:51, RP 10.1.8.254, flags: SJCL
    Vlan6, Forward/Sparse, 1d08h/00:02:51
CORE#sh ip igmp membership
Flags: A  - aggregate, T - tracked
       L  - Local, S - static, V - virtual, R - Reported through v3
       I - v3lite, U - Urd, M - SSM (S,G) channel
       1,2,3 - The version of IGMP, the group is in
Channel/Group-Flags:
       / - Filtering entry (Exclude mode (S,G), Include mode (G))
Reporter:
       <mac-or-ip-address> - last reporter if group is not explicitly tracked
       <n>/<m>      - <n> reporter in include mode, <m> reporter in exclude
 Channel/Group                  Reporter        Uptime   Exp.  Flags  Interface
 *,239.192.1.1                  10.1.2.254      01:37:06 02:56 2LA    Vl3
 *,239.192.1.1                  10.1.8.100      13:20:36 02:39 2A     Vl7
 *,239.255.255.255              10.1.2.11       02:00:04 02:56 2A     Vl3
 *,239.255.255.255              10.1.8.100      1d07h    02:33 2A     Vl7
 *,239.255.255.254              10.1.2.20       02:00:04 02:56 2A     Vl3
 *,239.255.255.250              10.1.2.100      02:00:04 02:59 2A     Vl3
 *,239.255.255.250              10.1.7.2        1d08h    02:18 2A     Vl6
 *,239.192.0.1                  10.1.2.254      02:00:01 02:03 2LA    Vl3
 *,224.0.1.40                   10.1.7.254      1d08h    02:17 2LA    Vl6
I noticed that in the sh ip mroute i've (*,G) and not  (S,G):
(*, 239.192.1.1), 13:49:06/00:02:29, RP 10.1.8.254, flags: SJCL
BUT NOT
( IP player, 239.192.1.1) 13:49:06/00:02:29, RP 10.1.8.254, flags: SJCL
  Incoming interface: VLAN 7, RPF nbr 0.0.0.0
Thanks for your help.
37 Replies 37
Hi Abdel,
can you please clarify exactly what do you mean with "work on VLAN 7 but not on others"?
This mean that when your receiver is in VLAN 7 you can see the announcement and actually get the stream?
Also please confirm that if I understood correctly: With receiver in VLAN 3 you see the Announcement but no stream. With receiver in VLAN 7 you see the Announcement and can get the stream.
Thank you.
Correct from vlan7 (same vlan used on server who send multicast) the player 10.1.7.100can see the announcement and get the stream.
From all other vlan i can get the announcment but the stream failed.
Thanks.
If you ping 232.10.10.10 from the source server you've replys?
The problem seems registering the source. Can you get a capture from the Core to confirm that the traffic is hitting the box?
Also can you get do debug ip pim and do clear ip mroute * and try again?
I dont understand why you wanted to ping 232.10.10.10.
From the server :
admin@10.1.8.1's password:
AvediaStream g44xx
admin@0094F3:~$ ping 239.192.1.1
PING 239.192.1.1 (239.192.1.1): 56 data bytes
64 bytes from 10.1.8.1: seq=0 ttl=64 time=0.223 ms
64 bytes from 10.1.8.1: seq=1 ttl=64 time=0.130 ms
--- 239.192.1.1 ping statistics ---
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 0.130/0.176/0.223 ms
admin@0094F3:~$ ping 232.10.10.10
PING 232.10.10.10 (232.10.10.10): 56 data bytes
^C
--- 232.10.10.10 ping statistics ---
4 packets transmitted, 0 packets received, 100% packet loss
admin@0094F3:~$
from the CORE:
CORE# debug ip pim
PIM debugging is on
CORE#clear ip mroute *
CORE#terminal monitor
CORE# debug ip pim
PIM debugging is on
CORE#
*Aug  3 14:23:13.372: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 224.2.127.254
*Aug  3 14:23:14.172: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 224.0.1.40
*Aug  3 14:23:30.074: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.255.255.250
*Aug  3 14:23:31.273: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.192.0.1
*Aug  3 14:23:31.572: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.255.255.254
*Aug  3 14:23:35.372: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.192.1.1
*Aug  3 14:24:11.774: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.255.255.255
*Aug  3 14:24:12.971: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 224.2.127.254
*Aug  3 14:24:13.174: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 224.0.1.40
*Aug  3 14:24:29.473: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.255.255.250
*Aug  3 14:24:29.673: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.192.0.1
*Aug  3 14:24:29.973: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.255.255.254
*Aug  3 14:24:35.072: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.192.1.1
*Aug  3 14:25:11.072: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.255.255.255
*Aug  3 14:25:12.473: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 224.2.127.254
*Aug  3 14:25:13.073: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 224.0.1.40
*Aug  3 14:25:28.373: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.255.255.250
*Aug  3 14:25:28.671: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.192.0.1
*Aug  3 14:25:29.175: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.255.255.254
*Aug  3 14:25:33.271: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.192.1.1
*Aug  3 14:26:09.672: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.255.255.255
*Aug  3 14:26:11.272: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 224.0.1.40
*Aug  3 14:26:12.272: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 224.2.127.254
*Aug  3 14:26:26.972: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.255.255.250
*Aug  3 14:26:27.975: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.192.0.1
*Aug  3 14:26:28.071: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.255.255.254
*Aug  3 14:26:31.774: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.192.1.1
*Aug  3 14:27:08.471: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.255.255.255
*Aug  3 14:27:10.173: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 224.0.1.40
*Aug  3 14:27:11.071: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 224.2.127.254
*Aug  3 14:27:25.671: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.255.255.250
*Aug  3 14:27:26.274: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.255.255.254
*Aug  3 14:27:26.274: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.192.0.1
*Aug  3 14:27:31.071: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.192.1.1
*Aug  3 14:28:07.272: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.255.255.255
*Aug  3 14:28:09.173: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 224.0.1.40
*Aug  3 14:28:09.871: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 224.2.127.254
*Aug  3 14:28:24.071: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.255.255.250
*Aug  3 14:28:25.072: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.192.0.1
*Aug  3 14:28:25.574: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.255.255.254
*Aug  3 14:28:30.372: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.192.1.1
*Aug  3 14:29:06.171: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.255.255.255
*Aug  3 14:29:08.371: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 224.2.127.254
*Aug  3 14:29:08.371: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 224.0.1.40
*Aug  3 14:29:23.373: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.192.0.1
Thks
Sorry, I was thinking in other mcast group :)
So the ping from the server worked, and Im assuming that the S,G appeared in the Core, and that it wasnt other device in the same VLAN replying, right?
If true I think that we need the pkt cap at this point...
Sorry maybe i don't understand what you asked me:
summary :
IPTV Server:10.1.8.1 and  the  player 10.1.8.100 on VLAN7
you asked me to ping from the server the  ip of multicast channel 239.192.1.1 i've an answer but from the same equipement:
AvediaStream g44xx
is it normal situation?
what do you mean by "hat it wasnt other device in the same VLAN replying, right?"
about the pcap trace i take my laptop and take the IP 10.1.2.200 (VLAN3) same to the player doesnt works.
i've the SAP annoucement but not the stream.
you can see the pcap trace in my previous answer yesterday with the attachement pcapmulticast2.zip.
Could be normal.
Just do a ping from the Server and send show ip mroute from the Core.
You have a capture in VLAN3, we need a capture from the server side.
Tnks
Hello Guys,
Hello Guys,
I'm back from the holidays.
I've done some test and i said a big mistake.
Sorry for this huge mistake!!!
here is the situation:
On the CORE, if i plug a VLC player on VLAN 7 it works but it doesntnt works in all other VLAN.
Therefore, we can focus the troubleshooting only on the core.
The settings i've done is the following:
Gateway IPTV-> 10.1.8.1
Enable multicast-routing
ip pim sparse mode in each SVI
define a RP -> 10.1.8.254 (Gateway of VLAN 7)
Do i need to add something in the settings in order to make multicast on different VLAN
