output drops dilemma on cisco 2960
Gsiaw
I'm having out put drops on ths interface which is an access port connected to a server.
I  removed the server and connected it directly to the host using a crossover cable and there was no packet drops, can anyone explain to me why that is the case? Evry interface in my network is 1G/full duplex
GigabitEthernet1/0/37 is up, line protocol is up
  Hardware is Gigabit Ethernet, address is b4a4.e323.b325 (bia b4a4.e323.b325)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:38:23, output hang never
  Last clearing of "show interface" counters 01:42:55
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3515
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     208452 packets input, 193401616 bytes, 0 no buffer
     Received 20767 broadcasts (20765 multicasts)
     0 watchdog, 20765 multicast, 0 pause input
     8428681 packets output, 11181884258 bytes, 0 underruns
paolo bevilacqua
They are not enough to worry about.
Anyway, if you have any QoS configuration, try removing it.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind.  Usage of  this posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Most likely you have transient congestion.  Consider if more than one gig ports sends to the same destination gig port, the latter will queue the excess.  If there's enough excess it will overflow the queue and be counted as drops.
If the congestion is transient, which would seem to be the case since your dropped packets percentage is about .04% (which is why Paolo is telling you not to worry about them), increasing your queue buffer should reduce or eliminate the few drops you're seeing.
Oh, and why one host on the connection has drops versus a different host, because usually different hosts make different traffic demands.  If you just move you server to another port on the same switch, assuming the port is configured the same as the original port, you'll likely get the same results.
