Net flow commands are not working in (IOS-XE 15.0(1r)SG6
Pandian G K
Netflow commands are not working in
(IOS-XE 15.0(1r)SG6 )  cat4500e-universalk9.SPA.03.03.00.SG.151-1.SG.bin running on WS-C4500X-32 2 slot switch.
Please suggest on this.
Rgds,
Pandian.
2 Accepted Solutions
Ivan Shirshin
This switch supports Flexible Netflow, which config guidelines are explained here:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/15.1/XE_330SG/configuration/guide/fnf.html
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Pandian / Sankar,
You need to use Flexible NetFlow on the new Cisco 4500 series. But the error you get with associating the ip flow monitor is a bug on the Cisco 4500. We have the details in our below blog:
http://blogs.manageengine.com/netflowanalyzer/2011/01/25/missing-out-traffic-with-cisco-4500/
Don Thomas Jacob
www.netflowanalyzer.com
NOTE: Please rate posts and close questions if your query has been answered
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
Ivan Shirshin
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
Hi Ivan,
I tried the same, but i am getting the below error when i call the monitor in the interface( physical, vlan and portchannal )
% Flow Monitor: Flow Monitor 'm1'
intf output nf: cannot be supported as match field
and when i issue sh flow monitor m1 command, i am getting the below o/p, in this e1 is inactive, how to activate that???
Flow Monitor m1:
  Description:       User defined
  Flow Record:       r1
  Flow Exporter:     e1(inactive)
  Cache:
    Type:              normal
    Status:            not allocated
    Size:              1000 entries / 0 bytes
    Inactive Timeout:  30 secs
    Active Timeout:    60 secs
    Update Timeout:    1800 secs
By
Sankar V
One more observation i found, In config terminal ip flow ingress & ip flow ingress layer2-switched are not available. I have enabled IP ROUTING in the global confguration.
Can any one suggest wat is the problem??
By
Sankar V
Pandian / Sankar,
Don Thomas Jacob
