Network documentation (for disaster recovery)
Marian Hercek
What are recommended commands to get input for network documentation (for disaster recovery)?
I've got 6500 with these modules: WS-SVC-FWM-1,
WS-SVC-IDSM-2, VS-S720-10G, WS-X6704-10GE, WS-X6748-SFP and dozens of WS-C3750E-48TD in couple of buildings.
So far I have these commands:
more system:running
show interfaces status
show vlan
show spanning-tree
show vtp status interface
show cdp neighbors
show etherchannel summary
2 Accepted Solutions
RKB04071984_2
I would say to have the configuration file is enough. Otherwise you should keep your topology documentation up to date in case of a disaster.
You could use the command archive config to save in another location your last configuration file. More instructions on the link below:
http://www.cisco.com/en/US/docs/ios-xml/ios/fundamentals/command/A_through_B.html#GUID-26CDF18C-A66D-488A-BA38-D85A70AD95DF
However this command is not available for FW and IDS modules. In these case you could use the Cisco Security Manager - CSM to avoid any lost.
Ronaldo
Peter Paluch
Hello Marian,
Apart from having a backup of your running-config, I suggest also making a backup of the following data:
  • vlan.dat
  • IOS images
  • any special files if located in FLASH
  • inventory of the device (show inventory to have a bill of materials if a physical component fails)
Best regards,
Peter
RKB04071984_2
Ronaldo
Peter Paluch
Hello Marian,
  • vlan.dat
  • IOS images
Best regards,
Peter
Thanks Peter for valuable suggestions.
