Network Redundancy
ross_rulz
Level 5
Level 5
Hi Guys,
Can someone please point me in the right direction with regards to my network setup. (please see network diagram attached).
At the moment we are in the process of moving out IT infrastructure offsite to a ISP DR site. We already have our own little DR site but my boss is looking for our main infrastructure to be going to a big DR site.
I've drawn up a quick network diagram of how it might look but need help from you guys on how I can setup redundancy if parts of the network will fail.
Any suggestions would be highly appreciated.
Ross.
Jon Marshall
Ross
Some of use can't read visio files. Could you repost as a jpg/png ?
Jon
Hi Jon,
I've attached the network diagram as a jpeg now.
Ross.
boss.silva
Level 5
Level 5
By looking at your diagram, just three things i've observed:
1) Might be only the drawing, but on the right side, there is only one firewall, but mentions a cluster. Is that correct?
2) Does that cisco ASA on the left side have a failover? Doesn't seem like it does. If not, i would advise you to put one. I don't understand the relation of the failover link to be between the center ASA (Council House Building) with the right side one.
3) Might be good to put the checkpoint firewalls in each switch, because if the external DMZ switch 1 crashes, you will get in trouble.
4) Would you have too much traffic traversing the 6509's? Because the link between the 6509-left and 3750 is 1gb fiber, and the link between the 3750 and the 6509-right is a fiber port-channel (density?).
Bruno Silva.
Hi Bruno,
Thanks for your input. I'll answer the questions best I can.
1. Yes the Checkpoint firewall on the right is part of the other two Checkpoint firewall's on the left as they are all in one cluster.
2. No the Cisco ASA on the left does not  have any failover. The relation between the Council house ASA and the one on the right hand side is there's another internal network that hangs off these ASA's and they need to be separated from our corporate inside network.
3. If the external DMZ switch 1 crashes the Checkpoint on the right hand side will take control.
4. There could be to much traffic on the 1gb link. I might need to ask the boss to get another 1gb link.
Ross.
