New network with Layer 3 switch and 7 Layer 2 switch how to set route network to internet from Layer 3
Dear,
I have confused that how to route inter-vlan traffic forward  to internet?  ISP cable connect to port 48. and live ip for example 1.1.1.1
Can you guide me ?
Thanks.
Junaid
5 Replies 5
Hi Junaid,
Assalamu Alikum,
To enable Inter VLAN routing on the switch by using the “ip routing” command.
then enable static routing on your core switch
for example :
switch(config)#ip route 0.0.0.0 0.0.0.0 1.1.1.1
switch(config)#ip default-gateway 1.1.1.1
(1.1.1.1 is a next hop address of core switch connected towards ISP router)
You can also enable routing by using port no
switch(config)#ip route 0.0.0.0 0.0.0.0 fa0/0
Khaleelur Rahman
*Please dont forget to rate if this info is helpfull
Walikumusalam,
But i want to connect ISP in core switch port. after connect port 48.  fine below command.
switch(config)#ip route 0.0.0.0 0.0.0.0 fa0/48 1.1.1.1
Hi Junaid,
please execute the following commands in your core switch
coreswitch:
coreswitch(config)#ip route 0.0.0.0 0.0.0.0 121.121.121.212
coreswitch(config)#ip default-gateway 121.121.121.212
Please Find the Attachment
Note : Please Let me know is there any other devices connected between coreswitch and ISP
Khaleelur Rahman
Thank you so much.
No there is no other device
Mean can i connect isp cable core switch of any port like fa0/48. no problem if i connect to port 24.
there is no need to change command.
Hi Junaid,
You are welcome..
Khaleelur Rahman
