Nexus 2248TP GE Fabric Extender
Szabo Tomi
Hi Alll,
I have a
I would like upgratde the software. I found the image for the 9k series, but for the 2k series is not found.
Is this only bug or the parents, the 9k can upgrade the 2k's software?
Thanks your answer,
Tamas
Reza Sharifi
You don't need any software for the 2ks.
Just upgrade the parent switch (9k in this case) and the parent switch will push the same image to all 2ks.
Reza Sharifi
Thank you!
Glad to help.  Just make sure the 9k supports the 2248 as this FEX is a few years old.
Good Luck!
Yes, the FEX connection has already done!
