Nexus 3k VPC problems
Claudio Battan
two nexus's 3k in VPC configuration with dedicated keepalive link.
If - for any disruption - the keepalive link goes temporary down, even when it returns UP (*) the only way to restore the correct functioning of the VPC is to ... restart one of the two NEXUS's.
And this creates an additional outage.
Does this seem normal to you, or is there something wrong with my config?
(*) UP means:
Peer status: peer adjacency formed ok
vPC keep-alive status: peer is alive
Configuration consistency status: success
Per-vlan consistency status: success
Type-2 consistency status: success
vPC role: primary, operational secondary
version 9.2(2) Bios:version 5.0.0
hostname CORE-B1
vdc CORE-B1 id 1
feature vpc
errdisable recovery cause vpc-peerlink
vrf context KEEPALIVE
vpc domain 10
peer-switch
role priority 8192
system-priority 8192
peer-keepalive destination 10.255.255.2 source 10.255.255.1 vrf KEEPALIVE
peer-gateway
auto-recovery
interface Vlan999
description PEER-KEEPALIVE
no shutdown
no autostate
vrf member KEEPALIVE
ip address 10.255.255.1/24
interface port-channel100
description VPC-Peer-Link
switchport mode trunk
spanning-tree port type network
vpc peer-link
interface Ethernet1/46
description VPC-Peer-Keepalive
switchport access vlan 999
interface Ethernet1/47
channel-group 100 mode active
interface Ethernet1/48
balaji.bandi
if the only vpc  keepalive  link go down, the peer-link up it hsould not see the effects on the nexus vPC domain.
can you post show vpc  and bot the side config to understand the issue.
BB
