Nexus 5000 interfaces
glen.grant
  First time trying to configure these .  Trying to get the peer links to work and have them in interfaces E1/1-4 .  When i do a show int status it looks like this and says sfp invalid. I see this on both sides . Anyone ever see this ?   These same model gbics work fine attached to a FEX on these boxes. Thanks for any help .  A firstimer on the Nexus gear.
Eth1/1        vpc peer link to T sfpInvali trunk     full    10G     Fabric Exte
Eth1/2        vpc peer link to T sfpInvali trunk     full    10G     Fabric Exte
Eth1/3        vpc peer link to T sfpInvali trunk     full    10G     Fabric Exte
Eth1/4        vpc peer link to T sfpInvali trunk     full    10G     Fabric Exte
Gbic in ports are this.
Ethernet1/1-4
    transceiver is present
    type is Fabric Extender Transceiver
    name is CISCO-FINISAR
    part number is FTLX8570D3BCL-C1
    revision is A
    serial number is FNS16062QU8
    nominal bitrate is 10300 MBit/sec
    Link length supported for 50/125um OM3 fiber is 100 m
    Link length supported for 62.5/125um fiber is 10 m
    cisco id is --
    cisco extended id number is 4
Pawan Sharma
Have you configured the port as switchport mode fex-fabric? The FET-10G only works for this mode.
Pawan Sharma
http://www.ebrahma.com
Pawan Sharma
https://itgears.io
5 Replies 5
glen.grant
    Do the peer links have special cables ?   Is it possible the fex's use this specific gbic and cannot be used as a peerlink connection ?
Pawan Sharma
Pawan Sharma
Pawan Sharma
https://itgears.io
    Yeah it appears these are for  fex connections only.  Just found out we have special twinax cables coming for the peer link connections.  Thanks for the info.
Any Time Dear... HTH
Pawan Sharma
https://itgears.io
Apart from switchport mode fex-fabric, make sure you enable feature fex.
