Nexus 5548UP and WCCP
ahmede_2
Hi there,
I know that the Nexus 5596UP with L3 card doesn't support WCCP (even with Version 7). will 5548UP be any different?
Ahmed
Reza Sharifi
The only difference between the 2 models is the numbers of ports (48 vs 96), but they both used the same software version. So, if the 5596 does not support it the same applies to 5548.
Ganesh Hariharan
Hi there,
Ahmed
Hi Ahmed,
WCCP feature supported platform under nexus family comes with N7k not with N5k. Also Data sheet doesn't show that listed feature as well.
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-5000-series-switches/data_sheet_c78-618603.html
Hope it Helps..
-GI
Rate if it Helpss.
