Nexus 7000 & Nexus 2000
Rosa Ladeira
Does anybody know if Nexus 7000 IOS is able to connect Nexus 2000 without Nexus 5000 interface ?
Rosa
9 Replies 9
letsgomets
I haven't done this personally but according to cisco you can connect fabric extenders to the 7000 chassis just fine.
Thanks for the answer.
Rosa
Rosa
Devavrat Oka
You must connect the Fabric Extender to its parent Cisco Nexus 7000 Series device equipped with a 32-port 10-Gigabit M1 module (N7K-M132XP-12), a 32-port 10-Gigabit M1-XL module (N7K-M132XP-12L), or an F2 module.
http://cco.cisco.com/en/US/docs/switches/datacenter/nexus2000/sw/configuration/guide/rel_6_0/b_Configuring_the_Cisco_Nexus_2000_Series_Fabric_Extender_rel_6_0_chapter_01.html
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9402/at_a_glance_c45-644087.pdf
And may I connect the N2K to the N7K using the dual-homed capability?
Many tks!
bonillajose
