Nexus 9000 ACL logs Not Sending To Syslog
jamie.mai
Hello, I have logging set up and see some logs getting to the syslog server, however none of the ACL logging is going there. I see the ACL logs with show logging ip access-list cache but not in show logging or on the syslog server. I haven't found documentation that explains this, if someone could point me to specific documentation or has any ideas on this I would appreciate it. We have tried different logging levels, etc and so far nothing, thanks!
2 Accepted Solutions
I don't know if the N9K works the same as the N7K in this regard, but make sure your logging levels are configured with equal or higher values:
N9K(config)# logging level acllog 3
N9K(config)# acllog match-log-level 3
N9K(config)# logging logfile [name] 3
balaji.bandi
jamie.mai
Thank you both, not sure what I had wrong exactly but resetting the logging levels again and it is working now.
