Nexus FEX and PXE booting
Daniel Davidson
I have a new network I am setting up in our server room using two Nexus 5596 and several FEX connecting back to them, and in general, it works great.
However, our cluster needs to do PXE booting in order to reinstall nodes when they are first installed or fail,  and it is timing out and failing when the ports are in trunk.
Current config:
cfs eth distribute
feature lacp
feature vpc
feature lldp
feature vtp
feature fex
fex 123
  pinning max-links 1
  description "FEX0123"
interface port-channel123
  switchport mode fex-fabric
  fex associate 123
  vpc 123
interface Ethernet123/1/3
  switchport mode trunk
  switchport access vlan 170
  switchport trunk native vlan 170
  spanning-tree port type edge trunk
  no shutdown
Normally, on an IOS system the spanning tree line will fix the problem, and when I change to an access port on vlan 170, everything works fine as well.  However, it seems something is causing this to time out, and I cannot find what it is.  This will be a fairly large environment soon, so modifying the port entry for every system that gets reinstalled will get tedious very quickly.
Any help greatly appreciated,
Dan
6 Replies 6
Jerry Ye
Is the server configured to use trunk on the NIC? Or after the PXE, it will use trunk?
You have the interface set to switchport mode trunk and when that is configured, switchport access vlan 170 will not take affect (this command is for switchport mode access). I think you need to investigate where is the time out comes.
jerry
was my thought too at first, but the line
should solve any problems with the vlan tag.
Do a show span int e123/1/3 detail and you should see something like this:
Timers: message age 0, forward delay 0, hold 0
   Number of transitions to forwarding state: 1
   The port type is edge by port type edge trunk configuration
If you stil have a timeout I would have a look with wireshark to investigate further.
regards,
pille
To answer two posts in one, the access line is there because I keep having to switch back and forth.  Right now, it is in trunk mode, so the access line is just there inactive for when I change it back.
Adding in a little more information that would have made things clearer earlier, the initial PXE boot works fine, but when the OS loads off PXE immediately after, it cannot get an IP and dies.
Leaving out the other vlans than 170 (which is the main one that matters here) :
sw-server-0-0# show spanning-tree int e123/1/3 detail
Port 3971 (Ethernet123/1/3, vPC) of VLAN0281 is designated forwarding
   Port path cost 1, Port priority 128, Port Identifier 128.3971
   Designated root has priority 4096, address 000c.dbcf.97e0
   Designated bridge has priority 33049, address 547f.ee93.7041
   Designated port id is 128.3971, designated path cost 6
   Number of transitions to forwarding state: 2
   Link type is point-to-point by default
   Bpdu guard is enabled
   Bpdu filter is enabled by default
   BPDU: sent 11, received 0
Is VLAN281 tagged? Meaning is the PXE server image have VLAN281 tagged? You configuration have VLAN 170 as native VLAN (non-tagged) and everything else will be tagged.
jerry
170 is the internal wired network of the cluster, and should be the untagged (main) link for systems in the cluster.  Outside of the cluster 281 is our normal untagged vlan.  I made a mistake trying to be quick and copied the wrong one.  Machines in the cluster should never use vlan 281.
Port 3971 (Ethernet123/1/3, vPC) of VLAN0170 is designated forwarding
   Designated root has priority 32768, address 0017.0f6a.d8aa
   Designated bridge has priority 32938, address 547f.ee93.7041
My question for you is, after login, is the server configured to use VLAN281 (trunked)?
Is VLAN281 configured with ip helper-address or any DHCP relay?
jerry
