Nexus 2000 dynamic-pinning
c.walsh
Level 3
Level 3
Does anyone have any info on how to configure dynamic-pinning, instead of static pinning on a Nexus 2224 connected to a 7009?
Can't seem to find anything on CCO!
Cheers
Colin
2 Accepted Solutions
Default configuration will do that. You don't have to configure anything.
jerry
That is correct.
jerry
9 Replies 9
Reza Sharifi
I don't think you can change that.  The only option I see under for example fex 101 is Fex max-link. And "sh fex det" show that the pinning is static
Was just reading that this is an option, in place of static pinning.
Reason is that if an uplink fails, the ports still have connectivity.
maybe a new feature then?
Maybe, but I am running 6.1.1 and I don't see it.  Did the doc say what version of code should have it?
Its mentioned in the Designing Cisco Network Architectures (ARCH) book by John Tiso!
Do you mean if a uplink failed, you want all traffic to moved the another fabric interface?
jerry
yes, that would be the reason
jerry
is that using the command "pinning max-links 1" ?
That is correct.
jerry
