NIM-1GE-CU-SFP 1000 MEG Full Issues
cchavezpadky
All,
I have a NIM-1GE-CU-SFP
I have the Media Type set to
interface GigabitEthernet0/1/0
media-type rj45
negotiation auto
If I try to set the speed too 1000 full, it wont let me. Only gives me an option for 10 Meg or 100 Meg.
Any ideas on why?
Router(config)#interface GigabitEthernet0/1/0
Router(config-if)#no negotiation auto
Router(config-if)#speed ?
10 Force 10 Mbps operation
100 Force 100 Mbps operation
Router(config-if)#
Thank you in advance for taking time to read this post.
Carlos
6 Replies 6
Leo Laohoo
Let the module auto-negotiate to 1 Gbps.
Any reason why you want to hard-code 1 Gbps when, by default, the network module will operate at the default speed of 1 Gbps?
I would prefer to hard to set the speed to 1000 meg Duplex full.  It does not appear I can do this with this particular card.
Are you saying there is not an option to hard set the port to GiG/Full?
I suspect the card will auto-negotiate to 1 Gbps, full duplex if left alone.
Reza Sharifi
In addition to Leo's comment, make sure you have the right IOS installed.
16.4.1 3.15
https://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
I upgraded to the latest code. Same issue. Thank you for your help.
cchavezpadky
Thank you everyone for the input. I have left at auto. I prefer hard setting but It will not allow me. So were good. Thank you again.
