NIM-ES2-8-P Not giving POE when installed in 4321 router
rarmitage
have a NIM-ES2-8-P installed in my 4321 router and I am not getting power for a Cisco 7945 IP phone. Do you have to do any special configuration on the interface port for POE
NAME: "Power Supply Module 0", DESCR: "110W AC Power Supply for Cisco ISR 4320"
PID: PWR-4320-AC ,
you need below PSU (look at the table 5)
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet_c78-612808.html
BB
13 Replies 13
other than the 'power inline' command on the ports, there is nothing much to configure. What is the output of 'show power inline' ?
Configuring PoE for FPGE Ports
SUMMARY STEPS
1. enable
2. configure terminal
3. cdp run
4. interface gigabitethernet slot/subslot/port
5. cdp enable
6. power inline {auto { auto [max milli-watts] | never }
7. exit
Leo Laohoo
Post the complete output to the command "sh power inline".
There was no output
What about the output of 'show power' ?
And the output of 'show platform diag'...
@rarmitage wrote:
There was no output
No output?  How about "sh inventory"?
NAME: "NIM subslot 0/1", DESCR: "NIM-ES2-8-P"
PID: NIM-ES2-8-P , VID: V01, SN: FOC22225QUA
Above is the module I thought I could get POE on the 4321. I just remember on the 2801 you had to upgrade the power supply for the extra wattage. Other then I am not getting POE the switch module is working,
Do you have enough power source in the router 4321 ?
can you post full inventory ?
BB
That's not the complete output, is it?
sh platform diag
Chassis type: ISR4321/K9
Slot: 0, ISR4321/K9
Running state : ok
Internal state : online
Internal operational state : ok
Physical insert detect time : 00:00:28 (00:45:17 ago)
Software declared up time : 00:01:08 (00:44:37 ago)
CPLD version : 17100927
Firmware version : 16.7(3r)
Sub-slot: 0/0, ISR4321-2x1GE
Operational status : ok
Internal state : inserted
Physical insert detect time : 00:01:44 (00:44:01 ago)
Logical insert detect time : 00:01:44 (00:44:01 ago)
Sub-slot: 0/1, NIM-ES2-8-P
Slot: R0, ISR4321/K9
Running state : ok, active
Software declared up time : 00:00:28 (00:45:17 ago)
Slot: F0, ISR4321/K9
Software declared up time : 00:01:29 (00:44:16 ago)
Hardware ready signal time : 00:00:55 (00:44:50 ago)
Packet ready signal time : 00:01:31 (00:44:14 ago)
Slot: P0, PWR-4320-AC
State : ok
Physical insert detect time : 00:00:47 (00:44:58 ago)
Slot: P2, ACS-4320-FANASSY
State : ok
sh inv
NAME: "Chassis", DESCR: "Cisco ISR4321 Chassis"
PID: ISR4321/K9 , VID: V04, SN: FLM2235W136
PID: PWR-4320-AC , VID: , SN:
NAME: "Fan Tray", DESCR: "Cisco ISR4320 Fan Assembly"
PID: ACS-4320-FANASSY , VID: , SN:
NAME: "module 0", DESCR: "Cisco ISR4321 Built-In NIM controller"
PID: ISR4321/K9 , VID: , SN:
NAME: "NIM subslot 0/0", DESCR: "Front Panel 2 ports Gigabitethernet Module"
PID: ISR4321-2x1GE , VID: V01, SN: JAB092709EL
NAME: "module R0", DESCR: "Cisco ISR4321 Route Processor"
PID: ISR4321/K9 , VID: V04, SN: FLM2231010C
NAME: "module F0", DESCR: "Cisco ISR4321 Forwarding Processor"
PID: PWR-4320-AC ,
BB
Thanks I thought a 110 watts was too low run a POE Module.
