NM-16ESW issue
jennyjohn
I have a site with a 2811 router which has a NM-16ESW module. The SVI does not seem to come up up even after connecting devices to the port, it always shows up down. Could not find any issue with the configuration. Am I missing something?
Router2811#sh ip int bri
Interface                  IP-Address      OK? Method Status                Protocol
Vlan397                    10.87.207.46    YES NVRAM  up                    down
Vlan497                    10.87.207.62    YES NVRAM  up                    down
The router configuration is as below
ip dhcp pool VOICE
   network 10.45.207.32 255.255.255.240
   option 150 ip 10.45.1.230
   default-router 10.45.207.46
   lease 30
ip dhcp pool DATA
   network 10.45.207.48 255.255.255.240
   default-router 10.45.207.62
   lease 30
interface FastEthernet0/0
description ----WAN Link-1----
ip address 10.45.200.74 255.255.255.252
duplex full
speed 100
interface FastEthernet0/1
description ----WAN Link-2----
ip address 10.45.200.78 255.255.255.252
duplex full
speed 100
interface FastEthernet1/0
switchport access vlan 497
switchport voice vlan 397
spanning-tree portfast
interface FastEthernet1/15
interface Vlan397
description -------VOICE VLAN-----
ip address 10.45.207.46 255.255.255.240
interface Vlan497
description -------DATA VLAN------
ip address 10.45.207.62 255.255.255.240
Router2811#sh vlan-switch bri
VLAN Name                             Status    Ports
397  VOICE                            active    Fa1/0, Fa1/1, Fa1/2, Fa1/3, Fa1/4, Fa1/5, Fa1/6, Fa1/7, Fa1/8, Fa1/9, Fa1/10
                                                Fa1/11, Fa1/12, Fa1/13, Fa1/14, Fa1/15
497  DATA                             active    Fa1/0, Fa1/1, Fa1/2, Fa1/3, Fa1/4, Fa1/5, Fa1/6, Fa1/7, Fa1/8, Fa1/9, Fa1/10
The router has a PPWR-DCARD-16ESW, but still the IP Phones do not seem to be getting power.
Thanks in advance
17 Replies 17
Yes, you are right: with EtherSwitch Network Modules these are only available options, I am sorry about that. Also to my knowledge there is no other option to PPWR-DCARD-16ESW daughter card which would allow 802.3af PoE negotiation. So to support the CP-7941G-GE phone with your network module the easiest way would be to use AC power source (CP-PWR-CUBE-3= with the appropriate country power cord) provided you have only couple of these phones. Also when EOS of NM-16ESW back in 2008, Cisco suggested replacement by NME-16ES-1G-P network module which is capable of both pre-stanadard and 802.3af, so you can consider this.
I am sorry I cannot provide better information or help.
Best regards,
Antonin
Thats fine, now the interface issues are all resolved.
We have lot of other phones which support Cisco Prestandard PoE, so we can use them.
Thanks Antonin
Hi Antonin,
       I have another 2811 router with a NME-16ES-1G module, will this support POE?
RTR281101#sh inventory
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811         , VID: V05 , SN: FCZXXXXXXXX
NAME: "Virtual Private Network (VPN) Module on Slot 0", DESCR: "Encryption AIM Element"
PID: AIM-VPN/SSL-2     , VID: V01, SN: FOCXXXXXXXX
NAME: "NME-16ES-1G: EtherSwitch SM 16 10/100T + 1 GE on Slot 1", DESCR: "NME-16ES-1G: EtherSwitch SM 16 10/100T + 1 GE"
PID: NME-16ES-1G       , VID: V03, SN: FOCXXXXXXXX
