NM-16ESW issue
jennyjohn
Level 5
Level 5
I have a site with a 2811 router which has a NM-16ESW module. The SVI does not seem to come up up even after connecting devices to the port, it always shows up down. Could not find any issue with the configuration. Am I missing something?
Router2811#sh ip int bri
Interface                  IP-Address      OK? Method Status                Protocol
Vlan397                    10.87.207.46    YES NVRAM  up                    down
Vlan497                    10.87.207.62    YES NVRAM  up                    down
The router configuration is as below
ip dhcp pool VOICE
   network 10.45.207.32 255.255.255.240
   option 150 ip 10.45.1.230
   default-router 10.45.207.46
   lease 30
ip dhcp pool DATA
   network 10.45.207.48 255.255.255.240
   default-router 10.45.207.62
   lease 30
interface FastEthernet0/0
description ----WAN Link-1----
ip address 10.45.200.74 255.255.255.252
duplex full
speed 100
interface FastEthernet0/1
description ----WAN Link-2----
ip address 10.45.200.78 255.255.255.252
duplex full
speed 100
interface FastEthernet1/0
switchport access vlan 497
switchport voice vlan 397
spanning-tree portfast
interface FastEthernet1/15
interface Vlan397
description -------VOICE VLAN-----
ip address 10.45.207.46 255.255.255.240
interface Vlan497
description -------DATA VLAN------
ip address 10.45.207.62 255.255.255.240
Router2811#sh vlan-switch bri
VLAN Name                             Status    Ports
397  VOICE                            active    Fa1/0, Fa1/1, Fa1/2, Fa1/3, Fa1/4, Fa1/5, Fa1/6, Fa1/7, Fa1/8, Fa1/9, Fa1/10
                                                Fa1/11, Fa1/12, Fa1/13, Fa1/14, Fa1/15
497  DATA                             active    Fa1/0, Fa1/1, Fa1/2, Fa1/3, Fa1/4, Fa1/5, Fa1/6, Fa1/7, Fa1/8, Fa1/9, Fa1/10
The router has a PPWR-DCARD-16ESW, but still the IP Phones do not seem to be getting power.
Thanks in advance
3 Accepted Solutions
As I have not yet received any response to my last post about the IP phone type connected and I should leave for a while now, there is one other thing for you to check: as your PPWR-DCARD-16ESW supports only Cisco prestandard PoE detection method please make sure your phone model supports this as well.
Best regards,
Antonin
That is correct: CP-7941G-GE does not support Cisco prestandard PoE negotiation. You can try to assign PoE for this model by static way. As this is Class 3 device it should take no more than 12.9 W according to Cisco data sheets. So the command (under the fa 1/x inerface) should read:
"power inline static max 12900".
Just be aware that static is the priority assignment, ie. all static PoE is applied first from the PoE budget.
I also hope that with the interface up/up all your other issues disappeared.
Best regards,
Antonin
Yes, you are right: with EtherSwitch Network Modules these are only available options, I am sorry about that. Also to my knowledge there is no other option to PPWR-DCARD-16ESW daughter card which would allow 802.3af PoE negotiation. So to support the CP-7941G-GE phone with your network module the easiest way would be to use AC power source (CP-PWR-CUBE-3= with the appropriate country power cord) provided you have only couple of these phones. Also when EOS of NM-16ESW back in 2008, Cisco suggested replacement by NME-16ES-1G-P network module which is capable of both pre-stanadard and 802.3af, so you can consider this.
I am sorry I cannot provide better information or help.
Best regards,
Antonin
17 Replies 17
Latchum Naidu
You must have an active client connection on vlan 1 for the SVI to go to an  up/up condition .  Once there is a live client on the switch you will see vlan 1 up/up .
Please rate the helpfull posts.
Naidu.
Thanks Naidu for the reply.
I am not planning to use VLAN 1. The SVI for VLAN 1 is shutdown.
I want SVI's for VLAN397 and VLAN497 up up, which is not happening
The thumb rule is that you must have an active client connection on vlan 1 for the SVI to go to an  up/up condition.
Naidu.
What is the output of a "show interface status"?  Do you have any of your switchports that participate in vlan 397 or vlan 497 on the NM-16ESW in the UP/UP condition.
Jerry
manju.cisco
Level 7
Level 7
Hi Jennyjohn,
looks you do not have any physical port which is assigned to vlan 397 or 497 in up/up status. Incase if cables are not connected, then connect the cable and make it up/up and the vlan will come up.
If you have your physical port admin down, then bring it up.
If you have a trunk port allowing vlan 397 & 497 then the SVI will come up ..... dont worry.......just
bring any of the above.interfaces to UP/UP status and you will see it yourself 😉
Manjunath
amikat
Please be aware that in addition to PPWR-DCARD-16ESW module you also need special power supply unit to supply inline power to your IP phones via the NM-16ESW module, ie. if the router was not originally ordered as Inline Power Bundle (Cisco-2811-AC-IP) than you need to swap the original P.S.U. for the one with P/N "PWR-2811-AC-IP=".
Best regards,
Antonin
Thanks Antonin for the reply.
I managed to get the PWR-2811-AC-IP, and installed it in the router (as per the document)
http://www.cisco.com/en/US/docs/routers/access/2800/hardware/installation/guide/10_hw.html#wp1161133
even still I cannot power up the IP phones. cdp and voice vlan are enabled on the port.
Router2811#sh power inline
PowerSupply   SlotNum.   Maximum   Allocated       Status
INT-PS           0       160.000     0.000         PS GOOD
EXT-PS           1         0.000     0.000         Ext. PS not supported
Interface   Config   Device    Powered    PowerAllocated
Fa1/0       auto     Unknown  Off        0.000 Watts
Fa1/1       auto     Unknown  Off        0.000 Watts
Fa1/2       auto     Unknown  Off        0.000 Watts
Fa1/3       auto     Unknown  Off        0.000 Watts
Fa1/4       auto     Unknown  Off        0.000 Watts
Fa1/5       auto     Unknown  Off        0.000 Watts
Fa1/6       auto     Unknown  Off        0.000 Watts
Fa1/7       auto     Unknown  Off        0.000 Watts
Fa1/8       auto     Unknown  Off        0.000 Watts
Fa1/9       auto     Unknown  Off        0.000 Watts
Fa1/10      auto     Unknown  Off        0.000 Watts
Fa1/11      auto     Unknown  Off        0.000 Watts
Fa1/12      auto     Unknown  Off        0.000 Watts
Fa1/13      auto     Unknown  Off        0.000 Watts
Fa1/14      auto     Unknown  Off        0.000 Watts
Fa1/15      auto     Unknown  Off        0.000 Watts
on every port, power inline is set to auto. Am I missing something?
Thanks in advance
Will you please check that you are using 12.3(8)T IP Base IOS release at minimum and then let us know the status of  -48V LED and EN LED of the module.
Thanks & Regards,
Antonin
We are running C2800NM-ADVIPSERVICESK9-M, Version 12.4(24)T4
and both the -48V LED and EN LED are up.
OK, that sounds good. I am sure you have checked cabling before, so what is the status of interface fa 1/x after connecting the phone (BTW whould you mind to tell us the phone type/model)?
Best regards,
Antonin
Best regards,
Antonin
The status of the interface fa 1/8 to which the phone is up down
FastEthernet1/8            unassigned      YES unset  up                    down
The phone model we are using is CP-7941G-GE. I checked the data sheet and it says that it does not support Cisco Prestandard PoE. I connected the CP-7941G and it worked fine. Now it is up up.
FastEthernet1/8            unassigned      YES unset  up                    up
Thanks Antonin
Best regards,
Antonin
Unfortunately the router does not support the command power inline static max 12900. I really hoped it would be there.
The only commands available are power inline auto and power inline never
Rouer2811(config-if)#power inline ?
  auto   Automatically detect and power inline devices
  never  Never apply inline power
