Output errors on TenGigabitEthernet interface
peteroseneff
Hi everyone.
TenGigabitEthernet interface is located on WS-X6708-10GE card in slot 4
show ver
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRC6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 08-Mar-10 10:39 by prod_rel_team
show int
TenGigabitEthernet4/5 is down, line protocol is down (notconnect)
  Hardware is c7600 10Gb 802.3, address is c471.fe9f.f42c (bia c471.fe9f.f42c)
  Description: EthChe2-2 iskra-asbr1.dev
  MTU 9216 bytes, BW 10000000 Kbit, DLY 10 usec,
     reliability 227/255, txload 1/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 10Gb/s
  input flow-control is off, output flow-control is off
  Last input 1w2d, output 1w2d, output hang never
  Last clearing of "show interface" counters 6w2d
  Input queue: 0/4096/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/4096 (size/max)
     128529625 packets input, 109059755103 bytes, 0 no buffer
     Received 415720 broadcasts (391202 multicasts)
     0 runts, 2827281 giants, 0 throttles
     135 input errors, 135 CRC, 28 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     160921836 packets output, 103761387833 bytes, 0 underruns
     28034176 output errors, 0 collisions, 0 interface resets
     0 lost carrier, 0 no carrier, 0 pause output
I swapped X2 transciever from "faulty" TenGigabitEthernet4/5 X2 socket to TenGigabitEthernet4/3:
show int
TenGigabitEthernet4/3 is up, line protocol is up (connected)
  Hardware is c7600 10Gb 802.3, address is c471.fe9f.f42a (bia c471.fe9f.f42a)
  Description: TEST
     reliability 255/255, txload 78/255, rxload 26/255
  Full-duplex, 10Gb/s
  Last input 00:00:16, output 00:00:29, output hang never
  Last clearing of "show interface" counters 1d23h
  5 minute input rate 1026088000 bits/sec, 167908 packets/sec
  5 minute output rate 3095002000 bits/sec, 398772 packets/sec
     28805228372 packets input, 23621209693908 bytes, 0 no buffer
     Received 6590998 broadcasts (2001784 multicasts)
     68402546265 packets output, 67041335367558 bytes, 0 underruns
As you can see the errors are magically disappeared.
So, I assum that TenGigabitEthernet4/5 X2 hole is defective. How can I confirm that using CLI?
Chaitra Shree
You should see link flaps or any errors related to te4/5 or module 4 under "show log" output. You could also check diagnostics of the module using :
"show diagnostics result module 4" and "show diagnostics events"
Chaitra
p.mcgowan
Level 3
Level 3
you can check the status of the port asic to see if you are dropping packets
show platform port-asic stat drop
smogra
Please clear the counters once and see if they are incrementing again.
If they are incrementing:
1. Check logs to see if anything is wrong with the affected interface.
2. And is there any performance issue beacuse of these errors.
If not, then this could be a cosmetic bug.
Hope that helps.
Cheers
Sweta
P.S. Please rate the answer if it was useful.
Thanks guys,
Whole WS-X6708-10GE card was changed to a new one and all errors dissapered after this operation. Card with errors returned back to Cisco partner for testing. Waitng for.
