Ordering cisco catalyst 4500 E
afath
Community Member
The Cisco Catalyst 4500 Series Supervisor 6L-E by default shipping, whether this card included with IP base image or not ? or else we need to order it seperately ?
Please any one help me to find out the same.
Thanks for your time
Abdul Fathah MK
Arumugam Muthaiah
Hi Absul,
This WS-X45-Sup6L-E will be shipped with LAN Base image by default. If you need IP Base image, you can order seperately. Please see the mode detail below,
S45EES_12253SG - Cisco Catalyst 4500E Cisco IOS Software ENTERPRISE SERVICES W/O CRYPTO
S45EESK9_12253SG - Cisco Catalyst 4500E Cisco IOS Software ENTERPRISE SERVICES SSH
S45EIPB-12253SG - Cisco Catalyst 4500E Cisco IOS Software IP BASE W/O CRYPTO
S45EIPBK9-12253SG - Cisco Catalyst 4500E Cisco IOS Software IP BASE SSH
The Cisco Catalyst 4500 Series Supervisor Engine 6L-E is supported only in Cisco IOS Software and is not supported in the Cisco Catalyst Operating System Software. LAN Base, IP Base, and Enterprise Services packages are supported.
The minimum software versions for the IP Base and LAN Base packages are as follows:
  • Supervisor Engine 6L-E, Cisco IOS Software Release 12.2(53)SG or later
For the Enterprise Services package the minimum software versions are as follows:
  • Supervisor Engine 6L-E, Cisco IOS Software Release 12.2(53)SG2 or later
Refer:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/data_sheet_c78-530856.html
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
Arumugam Muthaiah
Hi Absul,
Refer:
Aru
afath
Community Member
Thanks for ur support
