OSPF problem
tmesbah
Level 4
Level 4
We are having a problem to establish ospf neig with nortel contivity when using SUP 720, running in native mode IOS#12.2(18)SXF7". No problem in production when using SUP2/MSFC2 IOS#12.1(20)E3. Any change in IOS regarding OSPF ?
Here is some conf and debug:
AC65M40-02#sh ip ospf neig
Neighbor ID Pri State Dead Time Address Interface
142.205.159.2 1 INIT/DROTHER 00:00:32 142.x.x.2 Vlan159
AC65M40-02#sh ip ospf interface vlan159
Vlan159 is up, line protocol is up
Internet Address 142.x.x.250/24, Area 0
Process ID 1, Router ID 142.x.x.2, Network Type BROADCAST, Cost: 1
Transmit Delay is 1 sec, State DR, Priority 1
Designated Router (ID) 142.x.x4.2, Interface address 142.x.x.250
No backup designated router on this network
Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
oob-resync timeout 40
Hello due in 00:00:04
Supports Link-local Signaling (LLS)
Index 57/57, flood queue length 0
Next 0x0(0)/0x0(0)
Last flood scan length is 0, maximum is 0
Last flood scan time is 0 msec, maximum is 0 msec
Neighbor Count is 1, Adjacent neighbor count is 0
Suppress hello for 0 neighbor(s)
Message digest authentication enabled
Youngest key id is 1
AC65M40-02#sh run int vlan159
Building configuration...
Current configuration : 286 bytes
interface Vlan159
description WAN TLS
ip address 142.205.xx.255.255.0
no ip redirects
ip pim sparse-mode
ip ospf message-digest-key 1 md5 1 XXXX
standby 205 ip 142.x.x.1
standby 205 priority 255
standby 205 preempt
standby 205 authentication yyyyy
End
AC65M40-02# sh run
router ospf 1
log-adjacency-changes
area 0 authentication message-digest
passive-interface default
no passive-interface Vlan8
no passive-interface Vlan157
no passive-interface Vlan159
no passive-interface Vlan200
no passive-interface Loopback0
no passive-interface Loopback1
network 142.205.xx.0.255.255 area 0
AC65M40-02# debug ip ospf
000385: *Dec 27 10:00:31.437 EST: OSPF: Send with youngest Key 1
000386: *Dec 27 10:00:41.425 EST: OSPF: rcv. v:2 t:1 l:44 rid:142.205.159.2
aid:0.0.0.0 chk:0 aut:2 keyid:1 seq:0x5D1 from Vlan159
000387: *Dec 27 10:00:41.425 EST: OSPF: Rcv hello from 142.205.159.2 area 0 from
Vlan159 142.205.159.2
000388: *Dec 27 10:00:41.429 EST: OSPF: End of hello processing
000389: *Dec 27 10:00:41.437 EST: OSPF: Send hello to 224.0.0.5 area 0 on Vlan159 from 142.205.159.250
000390: *Dec 27 10:00:41.437 EST: OSPF: Send with youngest Key 1
8 Replies 8
cprice2k7
Level 4
Level 4
Is this the configuration from the Cisco? Can you post config from the Nortel? Have you looked at the authentication?
Try removing the authentication from the OSPF process and check.
Narayan
This might be because the Nortel box doesn't support LLS, in which case it should normally simply ignore the option.
Try configuring "no capability lls" under the router ospf process.
Hope this helps,
I added the command that hritter suggested and now I can see the Nortel box as OSPF neig.
Is this command will affect other cisco router that I have in the network "I am doing this in the LAB and we don't have other Cisco routers to test this behavior"?
Thanks hritter
LLS is mainly used in support of Cisco OSPF Graceful Restart (GR).
Disabling LLS will have no impact on the other Cisco routers in your network since you are not using OSPF GR in your configuration.
Hope this helps,
glen.grant
Can you ping the nortel box from the cisco ?
If you have other routers that need the authentication then you will have to put it back and disable it only for the interface that has the nortel on it or configure the nortel to use md5 keys.
IP OSPF AUTHENTICATION NULL
This command will override the global settings on a interface.
keduncan
Level 2
Level 2
The NORTEL's (BAY router) default timers (hello, Dead) are not the same as the Cisco (they were different back in the 90's.. I have not touched a Bay router since they were bought by Nortel). "Debug ip OSPF ADJ" and "Debug IP OSPF Events" should give you an error telling you if and what the differences are.
