outdoor switch suggestion
nflnetwork
hello can anyone recommend an outdoor switch?  temps could very well reach -30 degress celsius. does cisco have any such product ?
6 Replies 6
the IE3400 Rugged Series has an operating temperature of -40 to +75...
--> Built for harsh environments and temperature ranges (-40°C to +75°C)
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-ie3400-rugged-series/cat-ie3400-rugged-series-ds.html
Out of curiosity, where, in which country, are you planning on deploying the switch ?
Canada
Canada can get cold...I have family in Quill Lake, Saskatchewan, they spend the winter in Arizona because of the temperatures...
Or Florida
balaji.bandi
adding to other port. Idustrial switch right from IE 1000 can support your requirement, make sure you selected the correct model Looking at Operating temparature :
https://www.cisco.com/c/en/us/products/collateral/switches/industrial-ethernet-1000-series-switches/datasheet-c78-737277.html
BB
