Output drops on etherchannel
LucaSalvatore_2
Running a 3110X blade chassis and on alot of the etherchannels i'm seeing a lot of output drops.
running IOS version 12.2(55)SE.
here are some show commands:
BS001#show int po6
Port-channel6 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is e804.6288.9b06 (bia e804.6288.9b06)
  Description: LACP-ServerSlot-6
  MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 1/255, rxload 2/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is auto, media type is unknown
  Media-type configured as  connector
  input flow-control is off, output flow-control is unsupported
  Members in this channel: Gi1/0/6 Gi2/0/6
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 7240
show int gi1/0/6
GigabitEthernet1/0/6 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is e804.6288.a806 (bia e804.6288.a806)
  Description: Server Slot 6
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseX
  Last input 00:00:23, output 00:00:00, output hang never
  Last clearing of "show interface" counters 11w4d
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 9
#remote command 2 show int gi2/0/6
Switch : 2 :
GigabitEthernet2/0/6 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is e804.6288.9b06 (bia e804.6288.9b06)
  Last input 00:00:12, output 00:00:06, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 7231
BS001#show platform port-asic stats drop gi1/0/6
  Interface Gi1/0/6 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 9
    Queue 4
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 5
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 6
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 7
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
BS001#  remote command 2 show platform port-asic stats drop gi2/0/6
Switch : 2 :
  Interface Gi2/0/6 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
     Weight 2 Frames 7231
    Queue 4
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 5
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 6
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 7
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
Any idea whats going on?
I have a similar issue with a 3750 running the same version of IOS.  Never had this issue with previous versions of IOS.
QoS is disabled on this chassis.
CPU and memory are fine and utilization on the interfaces are low, monitoring shows it has never been above 100Mb.
5 Replies 5
LucaSalvatore_2
anyone?
andtoth
Level 4
Level 4
Hi Luca,
Output drops are caused by lack of egress buffers on interfaces. This is usually caused by bursty traffic, high number of packets in a short period. Although the average rate might not be high, if the port tries to send out a lot of traffic in short time, buffers might be not available and port will drop traffic.
Therefore I would suggest the following to be done:
- Try doing a SPAN capture on the ports to see if you can identify short bursts of packets, either unicast, multicast or broadcast.
- Configure the etherchannel load-balance method on the switch to something more granular, such as src-dst-ip to make sure that links are utilized evenly and more efficiently, rather than one link carrying much more traffic than the other.
Understanding EtherChannel Load Balancing and Redundancy on Catalyst Switches
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a0080094714.shtml
On the other hand, the output drops value does not seem very high and I would not be concerned about it if the packet loss is less than 1%.
Best regards,
Andras
While i understand the bufferers issue, i think something has changed in recent IOS.  I have a simialar blade running an earlier version of IOS 12.2(22) and i don't see this issue.  Same goes for some 3750s i have around as well.
Anyway - it does look like one link is being uses way more than the other.  Will using the src-dst-ip assist with more even load balancing?  What does cisco reccomend?
Hi Luca
When qos is disabled, all traffic uses txqueue 3 weight 2. So this is kind of taildrop which indicates congestion on this link.
Whether changing etherchannel load-balance algorithm helps or not depends on the traffic src/dst. By default it uses src mac, so if all traffic that causes congestion is from same host to the same destination host there will be no much difference if you change the load-balance to src-dst-ip. But if the traffic is more sporadic , say, from same source to different destinations, changing the load-balance algorithm will load balance the traffic better.
Cheers
Lixia
In older versions, there were some bugs which caused the output drops counter to stay at 0, although it was dropping traffic and the correct values are visible in HW counters with the 'sh platform port-asic stats drop' command.
I would recommend to try different load-balance methods to see if one helps, you might consider trying src-dst-ip first as that one usually proves to be the best choice due to the granularity it provides, your setup might be different though, so choose the one which fits you best.
Andras
