Packet loss when pinging from/to a cisco 3560e switch
I see Packet loss when pinging from/to a cisco 3560e switch. CPU utilization is normal.
Switches are running with IOS c3560e-universalk9-mz.122-35.SE5.bin.
Packet loss is observed for all the devices irrespective of directly connected or remote devices.
If i do self pinging, there are no packet loss.
I don't see any error on interface.
Can anyone please help me in resolving this issue.
27 Replies 27
Sure Veera,
Hope to hear from you soon.
Also please mark the question as answered if it resolves the issue.
Madhu
You may consider an upgrade to the fix version of the bug to avoid this in future too.
Madhu
I could have rate it 4 or 5, mistakenly rate as 1:)
Np. you may have an option to rate remaining posts in this :)
Kidding :)
Thanks Madhu.
Established TCP connection is from my laptop. I loged into the device.
will it impact user traffic if i Clearing TCP seesions?
It shouldn't be. You will loose ESTAB connection But since it is your laptop connection
only, you may reconnect.
Madhu
Ok.Thanks. I'll try it.
thank you for the suggestion: I successfully fixed my problems by clearing appended TCP connections.
Thanks.
A.
Ok Madhu.
Yes, Many of the switches were reloded long back 1yr before
As these switches are located in US ,I am afriad of taking show tech that if the switch hangs .
Hi Madhu,
I tried and it resolved my issue. Thanks a lot
My pleasure . Nice to hear issue resolved
Cheers,
Madhu
Just to add, we need to wait for 10 to 15 min once we execute these commands.
