Packet size setting
Hi all ,
I just configured the the ICMP-Jitter in my Cisco switch .. My problem i can't set the size of packet .. So is there any way to add size to the packet like 1500 , 5000 and so .  Your advice is highly appreciated .. Thanks in-advance ..
Kind Regards
7 Replies 7
Kindly, Any update ? Thanks in advance
PLz No one can advice in this issue .. Thanks
Carlos Villagran
Hi!
You mean, you configured an IP SLA with a ICMP-Jitter probe and want to know how to specify size of the icmp packets?
Sorry, the post is not really clear.
Best regards!
JC
Yes that's right .. I  configured an IP SLA with a ICMP-Jitter probe.. But i cant specify the packet size such as 1500 , 5000 and so.
In UDP-Jitter there is option called requested-size which specify the packet size .. In ICMP-Jitter i can't found  like this command .. So any way can using to specify the packet size in icmp-jitter .. Thanks in advance ..
Hi!
What router are you using? As far as I am concerned, there is no ICMP jitter SLA, you can specify the packet size with the  requested-size feature but using ICMP-echo option.
There is no point in doing an ICMP Jitter feature since as far as I understand, almost all jitter-sensitive traffic is UDP.
Hope it helps, best regards!
JC
maxrodri
Community Member
Hello Tareq,
Instead of use IP SLA ICMP-Jitter, you might try withIP SLA ICMP Echo which include a command called "request-data-size":
(Optional) Sets the protocol data size in the payload of an IP SLAs operation's request packet.
Example:
Device(config-ip-sla-echo)# request-data-size 64
I couldn't find if the switch can or can't support this IP SLA mode.
Refer to the link below:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipsla/configuration/15-mt/sla-15-mt-book/sla_icmp_echo.html
Maxrodri, Thanks for your replay .. yes you are right, but the ip sla echo just an show the delay parameters..  I want also show the packet loss for my network , So  the suitable IP SLA is ICMP-Jitter .... but my problem here i can't specify the packet size .. So is there any chance or not .. Thanks in advance ...
Kind Regards,
