POE issue on cat 3550
kmoshayedi
01:12:51: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/7
: Power given, but link is not up
I have connected a voip phone and ip camera getting the same error.. any idea ?
25 Replies 25
Leo Laohoo
Please post the command of "sh power inline"?
Switch#show power inline
Interface  Admin    Oper     Power        Device           Class
                            (Watts)
Fa0/1      auto  off           0.0  n/a                  n/a
Fa0/2      auto  off           0.0  n/a                  n/a
Fa0/3      auto  off           0.0  n/a                  n/a
Fa0/4      auto  off           0.0  n/a                  n/a
Fa0/5      auto  off           0.0  n/a                  n/a
Fa0/6      auto  off           0.0  n/a                  n/a
Fa0/7      auto  on           15.0  Ieee device
Fa0/8      auto  off           0.0  n/a                  n/a
Fa0/9      auto  off           0.0  n/a                  n/a
Fa0/10     auto  off           0.0  n/a                  n/a
Fa0/11     auto  off           0.0  n/a                  n/a
Fa0/12     auto  off           0.0  n/a                  n/a
Fa0/13     auto  off           0.0  n/a                  n/a
Fa0/14     auto  off           0.0  n/a                  n/a
Fa0/15     auto  off           0.0  n/a                  n/a
Fa0/16     auto  off           0.0  n/a                  n/a
Fa0/17     auto  off           0.0  n/a                  n/a
Fa0/18     auto  off           0.0  n/a                  n/a
Fa0/19     auto  off           0.0  n/a                  n/a
--More--
01:32:21: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/7
: Power given, but link         p
                            (Watts)
Fa0/20     auto  off           0.0  n/a                  n/a
Fa0/21     auto  off           0.0  n/a                  n/a
Fa0/22     auto  off           0.0  n/a                  n/a
Fa0/23     auto  off           0.0  n/a                  n/a
Fa0/24     auto  off           0.0  n/a                  n/a
Switch#
I have tried this on a few diff devices.. changed cables and also the switch  would this unit work with none cisco products ...
boss.silva
According to Cisco Output Interpreter:
%ILPOWER-3-CONTROLLER_PORT_ERR (x1): Controller port error, Interface [chars]:[chars].
Explanation: : A fault condition was detected on the power controller. An port
error has been reported by the inline power controller.
Recommended Action: 1. Make sure that the devices are correctly grounded.
2. Check the speed/duplex setting on the remote end of the connection.
3. Perform a shutdown and no shutdown on interface [chars].
4. If the device is not an IP Phone - disable inline power on this port.
5. If the error message continues: There are several know bugs related to
 this message such as CSCeb24148. Check the Bug Toolkit for bugs relevant
 to this device and software version.
The last option might be what you are facing
Bruno Silva.
device is a ip camera... and I also connect a snom ip phone and the phone keeps rebooting the power comes on for a few sec and goes off..
What is the IOS version running on this 3550?
Bruno Silva.
Switch#show ver
IOS (tm) C3550 Software (C3550-I9Q3L2-M), Version 12.1(20)EA1a, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Mon 19-Apr-04 21:42 by yenanh
Image text-base: 0x00003000, data-base: 0x006B3454
ROM: Bootstrap program is C3550 boot loader
Switch uptime is 2 hours, 10 minutes
System image file is "flash:/c3550-i9q3l2-mz.121-20.EA1a.bin"
cisco WS-C3550-24-PWR (PowerPC) processor (revision D0) with 65526K/8192K bytes
of memory.
Processor board ID CAT0737Y0TA
Last reset from warm-reset
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 4 has 1 Gigabit Ethernet/IEEE 802.3 interface
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
384K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0D:BC:BE:C6:00
Motherboard assembly number: 73-8100-07
Power supply part number: 341-0029-02
Motherboard serial number: CAT073702FR
Power supply serial number: DTH07341TNE
Model revision number: D0
Motherboard revision number: A0
Model number: WS-C3550-24PWR-SMI
System serial number: CAT0737Y0TA
Configuration register is 0x10F
V
but doing an ios UPGRADE TO
c3550-ipbase-mz.122-44.SE6.bin
it is
witch#
00:01:21: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state t
o up
00:01:28: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/11, chan
ged state to down
00:01:49: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/1
1: Power given, but link is not up
Switch#
Switch#
Switch#
Switch#sh ver
Cisco IOS Software, C3550 Software (C3550-IPBASE-M), Version 12.2(44)SE6, RELEAS
E SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 09-Mar-09 14:33 by gereddy
Image text-base: 0x00003000, data-base: 0x00D32668
Switch uptime is 2 minutes
System image file is "flash:c3550-ipbase-mz.122-44.SE6.bin"
Cisco WS-C3550-24-PWR (PowerPC) processor (revision D0) with 65526K/8192K bytes
of memory.
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
384K bytes of flash-simulated NVRAM.
Upgraded to a higher IOS and same issue
1.  Plug the end-point device directly to the switch.
2.  If problem persist, change patch cables.
been there .. done that.. I think the 3350 is not capable of powering POE devices other then cisco CDP stuff... just like  the 3524.. I upgraded IOS..
I guess If one does not have cisco device I am SOL .. POS switch.
Try this command on the interface-level:  power inline delay shutdown 20 initial 30
same
Switch(config-if)#power inline delay shutdown  20  initial 30
Switch(config-if)#no shut
Switch(config-if)#
17:03:51: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/2
Do you have a Cisco IP Phone or Wireless Access-point? Perhaps the ip phone/camera that you are plugging in is not compatible with the switch. Also, depending on the product, they have a compatibility list that you can check.
Bruno Silva.
