what would cause "Total output drops"
gavin han
Hi Guys,
what would cause "Total output drops"? we have been seeing calls drops on ip phones. most likely because of this.
interface GigabitEthernet1/0/7
switchport access vlan 2
switchport mode access
switchport voice vlan 201
srr-queue bandwidth share 10 10 60 20
queue-set 2
priority-queue out
mls qos trust dscp
auto qos voip cisco-softphone
spanning-tree portfast
service-policy input AutoQoS-Police-SoftPhone
GigabitEthernet1/0/7 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 5478.1a3b.381b (bia 5478.1a3b.381b)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:43, output 00:00:59, output hang never
  Last clearing of "show interface" counters 2d04h
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1092
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     698982 packets input, 164115935 bytes, 0 no buffer
     Received 6215 broadcasts (5245 multicasts)
     0 watchdog, 5245 multicast, 0 pause input
     1499748 packets output, 580484653 bytes, 0 underruns
8 Replies 8
Edison Ortiz
Bad cable
Oversubscription on the port or module
Speed/Duplex mistmatch.
among other things.
Haven't seen you for awhile Edison.  Nice to see you back!
Thanks Leo. Something called work got in the way.
LOL.
Take "work" off your contact list.
Sent from Cisco Technical Support Nintendo App
Leo Laohoo
100 Mbps link and you've got output drops?  What kind of phone is this?
Thanks Guys.
a PC is connected to the phone. i.e.
PC --> IP Phone ---> (Gi1/0/7) Switch.
any thoughts?
Ummmm ... Just for tricks-and-giggles, can you configure the port to auto-negotiate to 10 Mbps.
paolo bevilacqua
Remove QoS configuration, and ceck again.
