Port-channel Trunk not showing allowed vlans? C9407
lowfell
Level 3
Level 3
I have a port-channel setup as a trunk with allowed vlans, however when i do a show interface trunk it shows no allowed vlans can someone tell me why ?
interface Port-channel128
description
switchport trunk allowed vlan 2,201,208,253-255,705
switchport mode trunk
interface GigabitEthernet7/0/1
description
channel-group 128 mode active
interface GigabitEthernet7/0/2
description
output of show int trunk showing no allowed vlans?????
#sho int port-channel 128 trunk
Port Mode Encapsulation Status Native vlan
Po128 on 802.1q other 0
Port Vlans allowed on trunk
Po128 none
Port Vlans allowed and active in management domain
Po128 none
Port Vlans in spanning tree forwarding state and not pruned
Po128 none
#sho int GigabitEthernet7/0/1 trunk
Gi7/0/1 on 802.1q other 1
Gi7/0/1 none
Gi7/0/1 none
Gi7/0/1 none
Deepak Kumar
Check the port status Other and Native VLAN 0. The classified reason will be configuration mismatch at another end. Please check remote end device
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
M Talha
Dear lowfell,
Add these to your configuration
description
switchport trunk encapsulation dot1q    <--- Add tagging if you want your VLANS to be tagged !!
description
channel-protocol lacp   <--- Define channel protocol i.e LACP or PAgP
description
Talha
Deepak Kumar
Deepak Kumar,
We did have the other end connected, but now those switches are gone and i'm tidying up the config on the 9407, so, to cut a long story short, if the portchannel had been up, i could have seen my allowed vlans, yes?
Thanks for your help Deepak. i wrongly assumed because i had the allowed vlans in the config then i should be able to see them when I did show int trunk. Obviously I need thetrunk to be up first! 'll remember now.
thanks again.
